-   -   AC to OBA Conversion... PRESSURE SWITCH (http://www.jeepforum.com/forum/f13/ac-oba-conversion-pressure-switch-1550231/)
congerz83 07-17-2013 03:35 PM
http://www.zorotools.com/g/00058494/...uctAds&whence=
Can I use the above pressure switch in my set up? It looks more complicated than the typical "two-terminal" system? I have a 5 gallon tank coming & the WOLO 847 Siberian Express in the mail. The tank is rated for 200psi so a switch that cuts at 175 is ideal for me. PLEASE if anyone can help... I've got my finger over the ADD TO CART button now...
I know there are multiple threads on this topic. I just thought this would be the easiest way to a quick answer as time is at a minimum.
framanda 07-17-2013 10:52 PM
I recommend using this style. http://www.amazon.com/HornBlasters-1...ressure+switchThis is the same one I run on my York based oba. It's compacted, simple and has worked well for the last 4 months.
congerz83 07-17-2013 11:04 PM
AWESOME! Thanks for pointing me in the right direction... I went a bit higher with the PSI, but you helped a ton!
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
framanda 07-17-2013 11:45 PM
Glad I could help
congerz83 07-18-2013 07:44 AM
http://bit.ly/15KtZgi
Would this hose be the kind I need to connect the whole system?
framanda 07-18-2013 02:28 PM
I would use air brake line and push lock or compression fittings I got all my stuff from the local napa auto parts and it wasn't to expensive here's a link to my build thread. Toward the bottom of the page is how I did my onboard air. You are gonna need a oiler and oil water separator using a saden ac pump but after that all the components you need are the same.
Here you go http://www.expeditionportal.com/foru...GC-build/page4
congerz83 07-18-2013 03:39 PM
I'm not sure what compressor I have. The only name I can find on the compressor says "Delphi"
framanda 07-18-2013 05:35 PM
Regardless of what it is the cylinders in the pump need to be lubricated. Some use an air tool oiler on the suction port and a coalescing filter on the discharge port, and some have had luck disassembling the compresser and packing it with high temp racing grease. I'm sure you know this buy now but engine driven oba setups are difficult and expensive. But on the other hand electric oba can't compare to the performance of engine drivin comp either. Forum member Dynomite did an interesting and inexpensive oba using the stock ac comp but it use only useful for airing up tires his set up would not work with an aux tank for horns or air tools.
congerz83 07-18-2013 05:58 PM
Already handled. Bought an inline oiler and separator. I bought a slim 5 gallon tank. Air tools aren't the primary reason for the conversion, but with a 5 gallon tank, if I ever needed them, I guess I'll be covered. Planning on running at 175psi.
Dyn0mitemat 07-18-2013 06:01 PM
My setup works fine for everything. Put an inline filter after the compressor and it's completely fine. Powering my zip lockers just fine. Got about $75 bucks in mine and it fills my 35s up just as fast as my 2 stage home compressor
congerz83 07-18-2013 06:24 PM
Inline filter in addition to the inline oiler, separator, and inlet filter? It's just another standard inline air filter?
Mickey_D 07-18-2013 08:42 PM
248 Attachment(s)
Biggest thing I would add to all this is to go as big as you can on the air lines. I went 3/8" (I think) on mine and it was the worst. Go at LEAST 1/2" between everything. Including the manifolds. Anything where air has to flow through to your tools/tank should be 1/2". Gauges, pressure switches, etc can all be 1/4" or smaller if you like. But go big or go home with the "working" lines.
framanda 07-18-2013 11:45 PM
Sorry about that I did not realize you had done more to your set up. The last i remember it had reversed air couplers fittings and a modified tire inflator.
framanda 07-18-2013 11:51 PM
3/8 is plenty big. Most all automotive mechanics shops run 3/8 air hose. The only place I have seen 1/2 air hose was in heavy equipment shops running huge impact guns
congerz83 07-23-2013 12:02 AM
2 Attachment(s)
On the intake line... It goes FILTER/SEPARATOR/OILER/COMPRESSOR or FILTER/OILER/SEPERATOR/COMPRESSOR?
Attachment 649051
Attachment 649049
The time now is 06:14 AM.
