#1 | |
AC makes cold air no fan
Hello to all. I have a 2001 GC Limited with a 4.7. My AC fan comes on for a few seconds then shuts off (mine is the Automatic Zone Control system). It did this a few times then stayed on. Yesterday I got in the car (102 degrees outside) and the AC fan did not come on at all, however I was getting some cold air from the vents when the car was in motion. The fan came on and stayed on after about 15 minutes. I checked the FAQ section and did the Zone Control System - On-board Diagnostics. No codes in memory and no codes to display and the fan did not come on again. I looked at the compressor it is cycling on and off, I unplugged the low pressure sensor and the compressor stays off, when I bypassed the low pressure sensor the compressor came on and stayed on but the fan is still off.
My Haynes Manual says the AC system is complicated take it to the shop. Any ideas which way to go now?
PLMAC 2001 Grand Cherokee Limited, completly stock daily driver. |
#2 | |
I don't have the automatic zone control in my WJ but I do have it in my wifes '07 Pacifica and the system doesn't control the fan, just the blend doors to set the temp. I would think your fan should stay at the speed you select. You could check to see if the blower motor has voltage to it. Theres a chance the blower motor is bad. Does it come on if you turn on the heat?
2000 WJ 4.0L 42RE 242 TC 152,251 miles & counting |
#3 |
Thanks indept, I found the problem while checking voltage to the blower. I don't know the name of the part but it is located just behind the blower on the bottom of the hvac unit. Connector got a little hot and damaged the
large sensor. Check out the pictures. http://flickr.com/photos/paulmcspics/ Thanks for the help
#4 | |
what part do we need to replace? |
#5 | |
http://www.wjjeeps.com/blower_motor.htm |
#6 |
MEinSoCal you hit the nail on the head, the link shows it all.
Has anyone done the direct wire repair? This forum is great. Thanks again
#7 |
This is a very common problem on this vehicle, Blower motor resistor shorts out & then the wiring harness to the resistor all melts together (or vice-versa, but either way the result is the same).
Mopar makes a wiring/connector "pig tail" repair kit fairly cheap for the wiring/connector, bad news is that resistor is gonna set you back a pretty penny. Parts info: 5012699AA - Resistor - MSRP: $124.00 5102406AA - Wiring - MSRP: $16.00 |
#8 |
I did the Alternative repair method http://www.wjjeeps.com/blower_motor.htm it works great. Wahoo!! Another $140 I didn't have to spend.
#9 |
I have the same problem on my '03. I just ordered the new harness fix from Mopar Parts online for $20.97 with shipping. I'll hook it up and determine if my resistor is bad before blowing the $120 for that bad boy. I really appreciate all yall, I almost went to the stealership on this one! That would have set me back probably about $350 for a $20 fix!
#10 |
^ Good idea. Unless the connector plug has gotten way too hot and melted the contacts to the controller, it's probably OK. At least that was the case with mine. I just soldered new leads with automotive wire I had hanging around.
Love the inexpensive fixes!
Canadian Jeep Club Member Forty-Two |
#11 |
Just pulled my resistor pack and here's my outcome... Looks like I'll be splurging for a new resistor after all.
For those that have done the swap, how do I deal with the red and black wires coming directly out of the resistor? Is it a hack and splice job? Thanks all! ![]() ![]() |
#12 | |
#13 |
gotter fixed
Fixed mine up tonight after work. It took about an hour and about $120 with replacing the resistor. After I pulled my resistor I learned that it was burned very badly, I'm lucky I didn't have a fire from it. Check those wires yall!
#14 |
Does this apply to the heater as well?
I have a 2001 Jeep Grand Cherokee Limited with the 4.7. It has the auto-zone controls. Heat is being produced in the dash but is not coming out of the vents anywhere. The fan is running though. Dealership says that some kind of chute that directs the air through to the interior of the vehicle is broken and blocking the vents, and sending the air right back into the engine compartment. They want 150 for the part and 1000 for the labor.
![]() Thanks Rok |
#15 |
The Great White Ghost
Do a search for "Blend Door". It's a common problem.
A big thank you to whomever sponsored my membership!! 1974 CJ-5 258 3spd SOA on 31's [Sold in 1991] 1995 ZJ Limited 5.2 on 31's [Sold in 2009] 1990 XJ Laredo 4.0, nothing special [Sold in 2010] 1955 Willys CJ-5 #12171 [Sold in 2011] 1997 ZJ Limited 5.2 The Great White Ghost 1953 Willys M100 trailer |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
