AC Leaking inside and swamping my jeep - JeepForum.com
post #1 of 4 Old 05-31-2009, 09:37 PM Thread Starter
mrsholdenfarms
Already drilled the hole to clean out the drain, several times and blew it out with compressor. Think the first tech drilled all the way through the housing causing a hole in the back. After INDEPTH researching I think the seal between the drain and firewall is bad. So i removed it used plumbers putty, that was the wrong choice. And spent all day removing the plumbers putty. Finally decided on a woman's fix it and caulked the stew out of it. Worked for a few days. But my husband drives my jeep with ac on full blast. I think the caulk didn't dry throughly the water collected and kept it wet to the point that if finally caused a pocket of water and finally blew. Removed all the caulking. Am thinking of using something like RTV sealant i read on another sight and attempt to caulk the stew out of it and try to let it dry throughly. At this time i don't have the $1200.00 to have the dash removed just to take care of a $25.00??? seal. Does anyone have any suggestions?? Am at my wits end and have started graying.
mrsholdenfarms is offline
post #2 of 4 Old 06-01-2009, 02:28 AM
nwfjarhead
i think i have th same issue. i am also standing by
nwfjarhead is offline
post #3 of 4 Old 06-02-2009, 01:48 PM
nwfjarhead
***bump***
post #4 of 4 Old 06-02-2009, 02:40 PM
jimjam515
I damaged the housing by drilling and tried all the different caulks available but none worked, in the end I pulled the heater box again, replaced the lower housing with a good used one, replaced the firewall seal, fitted a short length of heater hose to throw the drain further into the chassis rail and refitted it all, no problem since and is probably the only fail safe way to guarantee sucess.
Not the news you want but it does work!
Regds, Mark
jimjam515 is offline
air conditioning leaking water inside robb4359 ZJ Grand Cherokee Forum 29 02-03-2016 07:45 PM
98GC sounds like water leaking inside JohnEgp ZJ Grand Cherokee Forum 1 06-13-2009 11:28 AM
A/C leaking inside WJ DaMitsuMan ZJ Grand Cherokee Forum 4 05-31-2009 08:33 PM
water leaking inside passenger side hellrazor ZJ Grand Cherokee Forum 1 06-23-2007 11:47 PM
A/C Condensation leaking inside PowayRider ZJ Grand Cherokee Forum 1 08-12-2005 05:50 AM
