AC issues - JeepForum.com
post #1 of 3 Old 08-25-2012, 10:40 PM Thread Starter
Allstarmike2k5
AC issues
I checked and found that my jeep is full of freon, around 50 psi, the clutch however doesn't want to engage. If I take a hammer and give it a light tap the clutch engages and blows cold air, as soon as I turn the AC off and back on the clutch doesn't engage again, is there a way to tighthen the clutch since the tap gets it to engage? Or is there another fix other than replacing the whole unit?
Allstarmike2k5 is offline
post #2 of 3 Old 08-26-2012, 08:44 AM
AVR2
AFAIK the only adjustment is with the shims that set the air gap. If your problem is a weak coil not being able to generate the necessary magnetism to engage the clutch, then removing shims to reduce the air gap might help the clutch engage... or it might do nothing.
TBH, if you're going as far as to get the pulley/clutch assembly off the compressor (which is what you'd have to do to fool with the shims), you might as well replace it with a brand-new one. JeepAir sells complete new assemblies - that's clutch, coil, pulley, bearing, shims and bolt - for $80. I'm going to be doing mine in the next few months.
AVR2 is offline
post #3 of 3 Old 08-26-2012, 09:38 AM
JS97ZJ
Check the high pressure switch.
JS97ZJ is offline
96 zj ac issues 88mjgilley ZJ Grand Cherokee Forum 0 08-25-2010 02:27 AM
High RPM issues and tranny issues Jeep Kid ZJ Grand Cherokee Forum 3 01-26-2010 04:09 PM
04 GC hvac issues-blower motor and other issues nation1979 ZJ Grand Cherokee Forum 1 09-02-2009 09:47 PM
99 JGC A/C issues smcjbc ZJ Grand Cherokee Forum 1 06-14-2005 12:40 PM
I got issues Fryloc ZJ Grand Cherokee Forum 9 05-07-2005 08:15 AM
