AC Evaporator tube leak (floor full of water) - JeepForum.com
post #1 of 3 Old 08-22-2013, 01:27 PM Thread Starter
KiloWatts
Well, it seemed like a common problem with an easy fix. I drilled the hole in the evaporator tube and cleaned it out with a coat hanger. But I don't think that solved the problem. First off, I was expecting water to come gushing out, but there was nothing. Secondly, I was expecting to find pine needles and gunk, but nothing.
I sealed the hole back up, and the water still leaks from where the tube connects to the firewall. I think the design is just flawed, and no matter what, water is going to drip backwards into the interior. Is there a possibility I can seal the hole better where it connects through the firewall?
Thanks in advance
KiloWatts is offline
post #2 of 3 Old 08-22-2013, 04:29 PM
shaban
Not much easy things you can do about that, if it's not plugged.
Someone posted how they cut out a window in the side of the frame from the wheel arch, and put a rubber hose on the AC drain tube, just a couple days ago.
shaban is offline
post #3 of 3 Old 08-22-2013, 04:53 PM Thread Starter
KiloWatts
So crazy. I don't have the skills for that. Hopefully I can find another solution - otherwise it's off to the mechanic to see what he can dream up.
