AC Drain Tube - JeepForum.com
post #1 of 14 Old 05-05-2006, 02:19 PM Thread Starter
tek2977
AC Drain Tube
Hello,
For some time now I am getting a musty smell when i turn on the AC.....Read about the TSB to correct a clogged drain tube since it sounds like what I may have. I followed the directions on this website(http://home.sc.rr.com/janet/TSB/24-06-96.htm) When I drilled through I stuck a wire hanger about 2 feet in and didnt feel anything, there was no water leaking out of the hole a drilled. I began to drive the wire up towards the top of the dash thinking my plug was above there.....debris began to come through the hole and out of the vents ( I had the AC on high). Still no water coming out of the hole.....???? I have been running the AC all day long and I have not noticed water coming out from under the car.....when I drive though, I can hear water sloshing from that area......HELP!
tek2977 is offline
post #2 of 14 Old 05-05-2006, 06:13 PM
sgarlic
You can spray half a can of lysol in to the intake cowl vent near the windshield on the outside with the a/c on full blast. That will kill mildew/bacteria growing on the evaporator core.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #3 of 14 Old 05-05-2006, 10:19 PM
Colorado 5.9
Colorado 5.9's Avatar
Usually when the drain hole is plugged, it will drain into the cab instead of outside. If all's your getting is the smell then I would do the Lysol thing.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #4 of 14 Old 05-06-2006, 05:12 AM Thread Starter
tek2977
Any idea what to do about the water sloshing???? I find it odd that running the AC on all day produced no water under the truck
tek2977 is offline
post #5 of 14 Old 05-07-2006, 08:17 PM
OneGravenKiss
I have water coming out on the outside and i notice today that i had a lake in my passenger side floor board,could it still be the heater core even though i disconnected the hoses in the engine and bypassed them?I am totally stumped on this one and i am growing tired of the water coming in. Pleas help!!!!
OneGravenKiss is offline
post #6 of 14 Old 05-07-2006, 08:40 PM
zjhitman
If the water is clear, it's condensation from the A/C. Do the fix listed in the beginning of the thread. If you did not have your heater core bypassed, and the water was green like anti-freeze, you would have a different problem.
zjhitman
zjhitman is offline
post #7 of 14 Old 05-08-2006, 09:09 AM
OneGravenKiss
well the heater hoses are already by passed becuase i thought the water would be coming from the heater core leaking so i disconnected them buuuutttt there is still water coming in and here is the good part,the a/c drains from the bottom of the car were its suppose to. When i pulled back the carpet and i felt the black enclosure where the coils are i noticed it was wet and there is this black piece that goes through the fire wall that has a sponge like material between it and the fire wall and when i put my finger between that alot of water comes out.
post #8 of 14 Old 05-08-2006, 11:38 AM
zjhitman
Just because some water comes out underneath, does not mean the drain is entirely clear. Do the fix in the first thread. That should fix your problem.
zjhitman
zjhitman is offline
post #9 of 14 Old 05-09-2006, 07:51 AM
OneGravenKiss
thank you
post #10 of 14 Old 05-09-2006, 10:36 AM
OneGravenKiss
oh another thing where would i find the plug needed for the hole that you drill? home depot or something like that?
post #11 of 14 Old 05-10-2006, 02:35 PM
sgarlic
Just use black RTV to fill in the hole. Much easier to find.
sgarlic is offline
post #12 of 14 Old 05-11-2006, 08:39 AM
OneGravenKiss
i rather use both so i dont have another leak
post #13 of 14 Old 05-11-2006, 10:59 AM
JamesEric
Lowes has 1/4 plugs in the specialty fastener drawers in the hardward section.
JamesEric is offline
post #14 of 14 Old 05-11-2006, 02:07 PM
OneGravenKiss
Thanks james!
AC Evaporator drain tube location ZJ 5.9 ???? Franck ZJ Grand Cherokee Forum 2 10-16-2007 01:39 AM
Where is the sunroof drain tube will_b ZJ Grand Cherokee Forum 2 06-15-2007 07:53 PM
Clogged AC drain tube? lma1973 ZJ Grand Cherokee Forum 14 11-26-2006 05:32 PM
A/C Drain Tube Location jim_usa ZJ Grand Cherokee Forum 2 07-31-2005 05:29 PM
Evaporator Drain Tube? -Joe- ZJ Grand Cherokee Forum 3 05-23-2005 12:33 PM
