Ac Condensor Leak On Carpet - JeepForum.com
post #1 of 3 Old 07-05-2006, 03:56 PM Thread Starter
oldtex
Have A Leak In Ac Condensor That I Have Had Looked At In Shop And They Blew Out The Drain And It Stopped Leaking For A Short Time. I Have Cleaned Out The Drain Several Times Since Then To No Avail--have Heard That One Time There Was A Service Bullentin From Jeep On This. Has Anyone Heard The Same Or Know Of A Fix Its Going To Ruin My Carpet
oldtex is offline
post #2 of 3 Old 07-05-2006, 04:09 PM
sgarlic
Your condensor is the radiator looking thing in the front of hte car. I'm guessing since you mentioned drain that you mean the evaporator core drain tube.
There is a TSB for this. http://home.sc.rr.com/janet/TSB/24-06-96.htm
Unfortunately, if there's been a lot of debris clogging the tube for a while, the evaporator probably has a hole in it from the corrosion that debris causes, and you'll end up having to replace the evaporator.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
post #3 of 3 Old 07-05-2006, 04:27 PM
Wookie06
Thanks for that link. That's exactly what I was trying to explain in this thread: http://www.jeepforum.com/forum/f13/1998-c-drain-289279/
Wookie06 is offline
wj leak drivers side carpet all wet. blackwhiteriot ZJ Grand Cherokee Forum 11 10-21-2011 10:51 AM
Took Condensor off and..... -cAcHe- ZJ Grand Cherokee Forum 3 08-07-2008 11:50 AM
A/C Problems - Leak at Evaporator Core & Condensor rflem550 ZJ Grand Cherokee Forum 10 06-24-2008 12:14 PM
A/C Condensor -cAcHe- ZJ Grand Cherokee Forum 8 06-12-2008 10:36 AM
Passenger carpet wet... A/C leak? Country Jeep ZJ Grand Cherokee Forum 3 07-17-2007 11:27 PM
