AC compressor delete options? - JeepForum.com
post #1 of 14 Old 05-23-2013, 04:34 AM Thread Starter
ErikTheRad
The A/C compressor in my 93 parted this cruel world many years ago and I have no intention of replacing it. Its nothing more than a dead-weight idler pulley. What are my options to ditch it completely? Does anyone offer a pulley/bracket or other apparatus to mount in place of the deceased compressor?
ErikTheRad is offline
post #2 of 14 Old 05-23-2013, 04:57 AM
AVR2
Yes they do. It's a very common mod. Dorman makes one that's $28 + shipping from RockAuto. Look up "AC Compressor Bypass Pulley".
AVR2 is offline
post #3 of 14 Old 05-23-2013, 08:06 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
2 options
remove the compressor and get the bolt in pulley and use the stock size belt or
remove or leave the compressor and use a shorter belt
if you want the motor to run way cooler, remove the condenser too
I removed the compressor and did a shorter belt
HighLonesome is offline
post #4 of 14 Old 05-23-2013, 10:29 AM
AaronButler
I dont know how the 93 differs from the 96 ZJs, but I ditched my AC, and AutoZone didnt have a belt that bypassed the AC (in their system anyway). Upon doing some research I found that a 79.5'' belt wrapped around everything MINUS the AC compressor. The pulleys were about 30-40 bucks from what I saw vs. a ~10-15 dollar belt.
1996 ZJ 4.0 Laredo... you know, the one with the ripped leather seats
AaronButler is offline
post #5 of 14 Old 05-23-2013, 04:36 PM Thread Starter
ErikTheRad
Aaron-- Are you absolutely POSITIVE on the length of the shorter belt at 79.5"?? I'd much rather just go to a shorter belt than have to use a do-nothing pulley. How is the belt tension and installation with the shorter belt?
post #6 of 14 Old 05-23-2013, 05:23 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Whoa whoa whoa. I don't think it's 79.5". My whole AC system is out and I'm running an 82.5" belt.
http://thespeedfreaks.net/showthread...-needs-belt-PN
Originally Posted by HighLonesome
2 options
I removed the condenser and put a PS and tranny cooler in its place.
In the garage: M1 4bbl
McCloudsZJ is offline
post #7 of 14 Old 05-23-2013, 07:47 PM Thread Starter
ErikTheRad
McClouds, not sure if it matters, but the thread you linked discusses belt length for a 5.9L. Mine is a 5.2
post #8 of 14 Old 05-23-2013, 07:55 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
It doesn't AFAIK.
Sent from my iPhone 6 using JeepForum
post #9 of 14 Old 05-24-2013, 12:49 AM
jabba974
I'm with AVR2...Buy the A/C eliminator pulley from Dorman products...That way you dont have to worry about having to remeber what belt you used when it comes time to replace it...and for the money they want for those, its not worth the headache to trying to figure out the correct length and routing of a different belt...and don't forget that if you do it that way, to make sure the water pump turns the correct way when your done..
jabba974 is offline
post #10 of 14 Old 05-24-2013, 02:28 AM Thread Starter
ErikTheRad
Removing the compressor shouldn't confuse anyone as to the routing of the belt, there would simply be one less pulley to wrap around. Everything else would go the same direction and wrap around the other pulleys just the same.
post #11 of 14 Old 05-24-2013, 04:58 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
There's a picture under the hood showing the belt routing for no compressor... I have faith in you guys. You can figure it out.
Those dummy pulleys are terrible quality. They're flimsy and mine squeaked out of the box. I threw it away and got the shorter belt.
post #12 of 14 Old 05-24-2013, 07:57 AM
HighLonesome
As did I!
Nice having a little room in that area isn't it? Summers are hot here tho is the downside.
post #13 of 14 Old 05-24-2013, 09:10 AM
AaronButler
ah, sorry, i didnt see that you had the v8. Mines the 4.0 and Im positive mines 79.5''
post #14 of 14 Old 05-24-2013, 11:14 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Makes sense. The 4.0 does use a shorter belt.
