AC Compressor clutch not engaging, but R134a pressure OK - JeepForum.com
post #1 of 22 Old 03-17-2012, 08:47 PM Thread Starter
polar8
My 96 ZJ 4.0 Laredo does not have AC. The compressor clutch doesn't engage under any circumstance. I read that a possible reason might be that the refrigerant pressure was low, so I went out and bought one of those recharge kits from Autozone. With the engine running and the AC on and high, the pressure was right in the green where it should be.
What can I check next?
Thanks
polar8 is offline
post #2 of 22 Old 03-17-2012, 09:00 PM
Oldfrog
2007 WK
Jump the plug on the compressor switch with a hefty paper clip, getting it to engage the clutch, then look at the gauge. ( BTW those cheap gauges arent very accurate)
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 22 Old 03-17-2012, 09:21 PM Thread Starter
polar8
Where can I find the compressor switch?
polar8 is offline
post #4 of 22 Old 03-17-2012, 09:24 PM
RedRocket1994
1994 ZJ
There are two, but if you jump the wires at the switch atop the accumulator (big can next to coolant res), the clutch should cycle. If it does, then that switch is bad.
1994 ZJ, 5.2L/46RH, NP242 & D44HD Swap, 4" SA Lift, 31" KM2s, and all the usual... I only lifted it so I wouldn't have to drive my grandma to church anymore... ;)
Remember: Every time you call a Jeep a "car", God kills a kitten.
Red Jeep Club #657
RedRocket1994 is offline
post #5 of 22 Old 03-17-2012, 09:26 PM
garver21
would like to know also im having the same issues
garver21 is offline
post #6 of 22 Old 03-18-2012, 12:36 AM Thread Starter
polar8
WOW! I was totally blown away by how easy and effective this repair was. I jumped the accumulator switch, and the compressor clutch activated. Then the reading on my refrigerant re-filler gauge was zero. I dumped the whole can in there and now my ac is ice cool. Removed the jumper and re-connected the cable and now the compressor clutch functions correctly and my AC is back. Thanks for the help!
However I still don't have heat- what could that be related to?
Here are some instructions on jumping the switch, I didn't know where to find it and this helped-
http://www.jeepforum.com/forum/f13/9...umper-1223272/
polar8 is offline
post #7 of 22 Old 03-18-2012, 01:47 AM Thread Starter
polar8
I decided it might be a good idea to flush the heater core in an attempt to get my hot air back. Flushed it using the garden hose method and the coolant that came out was definitely pretty rusty. Reconnected everything and now the air is warm. Not hot yet though, so I think I might go buy one of those heater core flush kits and try that method.
polar8 is offline
post #8 of 22 Old 03-18-2012, 05:40 AM
merlot2twisty
You might just want to do a complete cooling system flush.
Put the flush in the radiator and follow the instructions. Usually you drive the vehicle for several miles and then drain.
**VERY IMPORTANT**
Once you have removed all the flush and gunk, it's important that you refill the engine with distilled or dionized water (and antifreeze/coolant.) Water from your garden hose is useful for flushing or as an emergency or temporary fill, but there are far, far too many minerals in it that will wind up as crusty deposits in your engine, reducing its ability to transfer heat.
We're going off-grid and moving to Texas! --
Check out our YouTube Channel! http://youtube.com/user/theratracelosers/
merlot2twisty is offline
post #9 of 22 Old 03-18-2012, 12:06 PM
garver21
sry for the hijack
but if i jump the connector an my clutch engages an when i plug it back in nothing happens ,,, yes a/c is on max, yes it has freon in it ..... so do i need to empty the system to replace the switch on top of the accumlator???? sry for the bad grammer
garver21 is offline
post #10 of 22 Old 03-18-2012, 01:52 PM
Oldfrog
2007 WK
Help me to follow you.
You jumped the connector.
The compressor clutch engaged.
This is where I lost you:
You "plug it back in"....and nothing happens.
Please explain.
Oldfrog is offline
post #11 of 22 Old 03-18-2012, 01:53 PM
Oldfrog
2007 WK
Glad you got it going !
If the flush doesnt help the heat, take a look at :
1. Blend door
2. Thermostat.
Oldfrog is offline
post #12 of 22 Old 03-18-2012, 02:04 PM
Tangfan
Need to do this to mine.
Tangfan is offline
post #13 of 22 Old 03-18-2012, 02:27 PM
Mickey_D
Please explain.
Hope this helps.
He unplugged the connector. He jumpered the connector and the compressor fires up. He takes out the jumper and plugs it back in and the compressor no longer works.
This means the switch the connector plugs into is bad. He's asking if he needs to evacuate the system to replace the switch.
And the answer to his question is : Yes.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #14 of 22 Old 03-18-2012, 04:01 PM
cougar357
1994 ZJ
If garver21 is replacing the low pressure cycling switch on the accumulator an
evacuation is not necessary. There is a schrader valve under the switch, just unscrew old one screw on new one. Either way you still dont have to evac to install a new switch.
Last edited by cougar357; 03-18-2012 at 04:37 PM. Reason: wrong person needing help
cougar357 is offline
post #15 of 22 Old 03-18-2012, 04:29 PM
samsonitesamson
That's not what he was doing at all, he was getting in compressor to cycle so that he could charge the system to the point that the compressor would kick on by itself.
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
A/C Compressor Not Engaging swataz ZJ Grand Cherokee Forum 17 04-15-2015 03:34 PM
A/C Compressor not engaging! cobrakillerta WK Grand Cherokee & XK Commander Forum 4 05-24-2012 07:37 AM
A/C clutch not engaging. smholden ZJ Grand Cherokee Forum 6 05-12-2009 12:26 PM
AC Compressor clutch is not engaging sniperdude ZJ Grand Cherokee Forum 6 05-05-2009 08:07 PM
A/C compressor engaging when A/C is not on... jdbell2004 ZJ Grand Cherokee Forum 13 03-11-2008 10:11 PM
