abs tone ring removal? - JeepForum.com
post #1 of 9 Old 11-22-2006, 08:21 AM Thread Starter
rdrbssr11
when i had my super 35 kit installed, the shop skipped over swapping the abs tone rings. i noticed that immediately because my abs light was on when i got in my jeep. i asked what the deal was and he said getting the old tone rigs off my original axles is next to impossible because they tend to crack when trying to be removed. he said he could try to remove them, but if they break he will have to get some new ones from the dealer on my account. is it me or does it seem like he's trying to squeeze some money out of me? i thought those tone rings were steel, so if they put the torch ot it before popping them off shouldn't they come off pretty easy? has anyone priced these rings before new?
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #2 of 9 Old 11-22-2006, 08:30 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Call up Randy's Ring & Pinion - I am nearly positive they sell them.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 9 Old 11-22-2006, 08:36 AM
goodolboy71
the shop people are just lazy bastids then.....i have never had 1 crack on me on the 11x billion sets we have swapped out for folks....it seems when TJ guys get spares they usually get non ABS ones from a cherokee ,etc, all i have ever had to do was heat the ring with a propane torch, then tap it off a little with a hammer an it will fall right off, heat it a little more and tap it onto the new shaft
93 ZJ, 4.0, np242, 4 in F>R , 33's, Arb Bumper, Warn XD 9000, Home depot Rack, lightfoce 170's and some blingy shny 5 star rims,8.8 lsd, d30 /ox locker, JCR Rock Rails
74 CJ5- total restoration from ground up, 3 spd, 304 V8, 32's
goodolboy71 is offline
post #4 of 9 Old 11-22-2006, 08:49 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
just use any bearing puller. No torch needed
zaq123 is offline
post #5 of 9 Old 11-22-2006, 12:46 PM
FearTheDentist
Just a suggestion...
FearTheDentist's Avatar
I had a machine shop pull mine, hone them to fit the new outers, and press them on for $50 each, no fuss. Might want to try a different shop.
'04 4.7 WJ 6" Clayton's, full width 60\14b, 37" Nitto mud grapplers, lots of bits and pieces
FearTheDentist is offline
post #6 of 9 Old 11-22-2006, 02:17 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Old tone ring should go on new axle shafts without any modification.
Just remove them from old shafts, wire brush them good (they will look like new) and press them on.
You can use 2" PVC pipe to get the tone rings started (about half way)
than finish seating them with an aluminum punch
zaq123 is offline
post #7 of 9 Old 11-22-2006, 03:33 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I broke mine in half attempting to pull it off when I broke the shaft awhile back. Of course we didn't have a shop and nice tools. We were in a creek bed. Instead of ordering a new tone ring, I disabled the ABS. No problems or worries since.
My braking distances have shortened as well.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 9 Old 05-21-2016, 12:48 PM
silverado78
2007 FSJ Cherokee
hi i own a jeep grand cherokee.. esp bas /abs and tyracction lights came on, shut the cruise control off so pulled over and shut motor off and re-started and lights went off but motor missed and sputtered for awhile until lights came on again and ran good but lights remained on and cruise control did'nt work. any suggestions to what this could be? speed sensor? pat
silverado78 is offline
post #9 of 9 Old 05-21-2016, 05:25 PM
1996maroonzjf
This is the ZJ Gand Cherokee (93-98 ) section. What year is yours? ZJs do not have esp or traction control.
-Tim
96 4.0 Laredo, 42RE, NP242, HP30 & D35c 3.55, OME 2.5" HD Coils, Bilstein 5100s, IRO Adj. LCAs
1996maroonzjf is online now
broken abs tone ring schu98ZJ ZJ Grand Cherokee Forum 3 11-09-2008 12:23 PM
WJ Tone ring Width WJJEEPIN ZJ Grand Cherokee Forum 1 08-21-2008 10:36 PM
4.7 tone ring and swap questions itismejoshy ZJ Grand Cherokee Forum 9 12-06-2007 09:22 PM
Damaged tone ring hatchmt ZJ Grand Cherokee Forum 4 06-28-2007 09:18 AM
ABS\tone ring question FearTheDentist ZJ Grand Cherokee Forum 4 10-25-2005 09:24 PM
