ABS\tone ring question - JeepForum.com
post #1 of 5 Old 10-25-2005, 06:35 PM Thread Starter
FearTheDentist
Just a suggestion...
FearTheDentist's Avatar
We're just about done putting a Ford 9" front on my '04 WJ and I came across a minor issue. The wheel hubs are from a TJ and the ABS tone ring from my WJ hubs is ~ 30\1000 smaller inside diameter (ie don't fit). I could have these machined to fit, but I was wondering if anybody here has dealt with a similar situation and if so, what they did. I could always get a set of tone rings from a TJ, but I don't know if the tooth spacing is the same, or if that even matters.
I've heard of a lot of people disabling the ABS on ZJ's and preferring it that way- what are people's thoughts on just disabling it on the WJ? If I do that, I know the simplest way is simply pulling the ABS fuse, but will that leave the ABS warning light illuminated on the dash all the time? I heard of someone using a resistor somewhere in the system to trick the ABS computer into thinking the sensors were working- has anyone heard of this?
I'd appreciate people's thoughts on the matter.
Thanks!
'04 4.7 WJ 6" Clayton's, full width 60\14b, 37" Nitto mud grapplers, lots of bits and pieces
FearTheDentist is offline
post #2 of 5 Old 10-25-2005, 06:40 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
This may not work on a WJ but on my TJ, I found two ABS relays inside the PDC (Power Distribution Center) inside the engine compartment. It's a small box with relays and fuses inside. Pulling both ABS relays completely disabled my ABS system and the ABS light after installing a Dana 44 in the rear that didn't support ABS.
Jerry Bransford is offline
post #3 of 5 Old 10-25-2005, 06:50 PM Thread Starter
FearTheDentist
I know right where you're talking about, I'll try it. How did you like your TJ w\o ABS?
post #4 of 5 Old 10-25-2005, 06:53 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
I think ABS fuse will do the trick with the light as well. Is it your DD? If not, don't worry about ABS.
zaq123 is offline
post #5 of 5 Old 10-25-2005, 08:24 PM
ZJ_COWBOY
ZJ_COWBOY's Avatar
1994 ZJ
Even if it is you can still run with out ABS. I have for 2 years and no major problems. It is quite easy to lock up on dirt roads tho (Can we say BRAKE CHECK?). As long as you know how to control a skid, youll be fine.
RIP 93' ZJ
RIP 98' Dodge Neon
2001 Neon getting 30 MPG w00t!
94 ZJ $200 Project.
ZJ_COWBOY is offline
abs tone ring removal? rdrbssr11 ZJ Grand Cherokee Forum 8 05-21-2016 04:25 PM
broken abs tone ring schu98ZJ ZJ Grand Cherokee Forum 3 11-09-2008 11:23 AM
WJ Tone ring Width WJJEEPIN ZJ Grand Cherokee Forum 1 08-21-2008 09:36 PM
4.7 tone ring and swap questions itismejoshy ZJ Grand Cherokee Forum 9 12-06-2007 08:22 PM
Damaged tone ring hatchmt ZJ Grand Cherokee Forum 4 06-28-2007 08:18 AM
