ABS & regearing to 4.10 question - JeepForum.com
post #1 of 2 Old 06-22-2009, 11:55 AM Thread Starter
genislav ronen
hi guys
does the abs system works after regearing to 4.10 ?
ronen
1999 WJ /IRO 6" C.Path LA F&R /clayton's 4 linked rear end /D30-ARB /D44A- Aussie'd /Chromoly U-Joint F.Axle /242hd /4.10's /FOX 2.0 shocks /JKS shock adapters /F.Adj T.Bar /HD double SS/Pitman drop kit /T.Woods F.double cardan d.shaft +pinion yoke&TC yoke /265/75/16 bf mt /Solid HD dana 30 cover/Double open air fillter/ black rock 4" bs /Lower F+R C.Spring Retainers /4" front B. Stops /SUPERCHIP /Addco Rear HD Sway Bar /Rock Sliders /T.case skid plate /HAYDEN hd gear radiator
genislav ronen is offline
post #2 of 2 Old 06-22-2009, 12:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
abs is independent of gearing.
ratmonkey is offline
Regearing question for lift. WJjeeper ZJ Grand Cherokee Forum 11 12-10-2009 04:51 PM
Quick question on regearing and carriers. the88thpianoman ZJ Grand Cherokee Forum 0 06-27-2009 08:18 PM
regearing question Haleyrz ZJ Grand Cherokee Forum 36 03-09-2009 11:11 AM
Regearing question Ned97sahara ZJ Grand Cherokee Forum 19 04-01-2007 07:42 PM
got a question about regearing for gas mileage calimove ZJ Grand Cherokee Forum 12 08-24-2006 12:38 PM
