abs pump 93 vs 95 - JeepForum.com
post #1 of 6 Old 05-18-2013, 06:16 PM Thread Starter
Afdude88
So i was searcing through the jy the other day and i found a mopar abs pump that looks fairly new (like less than a year old) in a 95.
I was going to put it in my 93 just because im trying to slowly rebuild the brake system to be able to stop my 6x12 enclosed more safely
Are there any difference in the two years (abs pump wise) that i should be aware before dishing out the cash for the newish pump?
1993 Grand Cherokee Limited 4.0L AW-4
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #2 of 6 Old 05-23-2013, 11:42 PM Thread Starter
Afdude88
Bump for some insight please
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #3 of 6 Old 05-24-2013, 07:23 AM
Marcos
'95 is different from '93. To use it you would need the computer and Master Cylinder/reservoir from the '95. Also, a '95 would have rear discs, whereas the '93 would have rear drums.
Marcos is offline
post #4 of 6 Old 05-24-2013, 07:51 AM Thread Starter
Afdude88
I had always thought that the rear axle set up didnt matter. You dont have to change the abs pump when you do the drums for disc swap right?
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #5 of 6 Old 05-24-2013, 10:58 AM
Marcos
Not absolutely required, but there might be some minor calibration differences. If I recall correctly, in '94 when there were both discs and drums used in the rear, the part numbers for the HCU, ABS Computer, and Master cylinder were different between disc and drum. But not the proportioning valve, go figure.
Marcos is offline
post #6 of 6 Old 05-24-2013, 12:39 PM Thread Starter
Afdude88
So not work it t put in my own zj. Worth the buy for a resell maybe?
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
