ABS on No Anti-Lock Action - JeepForum.com
post #1 of 9 Old 12-27-2009, 07:32 PM Thread Starter
acemechanic
1993 FSJ Cherokee
abs light on , anti-lock brakes not working
my 18 year old kid just got this Grand Cherokee, its in good shape
i would feel better if the abs did work
also the right rear wheel is locking up under medium braking on snow packed roads
haven't checked yet, but i would guess it's either brake fluid or a axle seal is leaking onto the shoes and drum
cycled the key and checked for codes, just got the 5/5 so i guess there's nothing stored in the computer
any suggestions for getting the abs working?
acemechanic is offline
post #2 of 9 Old 12-27-2009, 07:42 PM
ZeeJay1997
Cant pull ABS codes with key.
Is light on as soon as it's cranked or does it come on after it is rolling?
ZeeJay1997 is offline
post #3 of 9 Old 12-27-2009, 07:54 PM Thread Starter
acemechanic
1993 FSJ Cherokee
abs on right away ( according to my kid) , i'll check for sure tomorrow
post #4 of 9 Old 12-27-2009, 08:16 PM
ZeeJay1997
You can disconnect the battery, reconnect, then start it and see if the light comes on right away befor rolling. If so, problem with voltage to controller or controller itself.
If it doesnt come on until it rolls, suspect wheel sensor.
It's easy enough to check the tone rings for obstructions/damage and clean the pickups at each wheel. I'd start at the one that's grabbing.
BTW, the sensors are gapped so clean them on the vehicle unless you can set them back to where the were.
post #5 of 9 Old 12-28-2009, 04:02 AM Thread Starter
acemechanic
1993 FSJ Cherokee
light does come on right away.
disconnected the battery, reconnected , turn key to run position, light came on.
started the engine let idle, it stayed on.
you believe its in the controller?
thats the module tied into the mastercylinder?
options are to send in for repairs, or if we decide not to, there is a fuse that can be pulled to disable the abs system?
thanks
post #6 of 9 Old 12-28-2009, 04:05 AM
ZeeJay1997
What year Grand is it??
post #7 of 9 Old 12-28-2009, 05:35 AM Thread Starter
acemechanic
1993 FSJ Cherokee
its a 93 Jeep Grand Cherokee
post #8 of 9 Old 12-28-2009, 10:51 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Start with the fuse first, check it, maybe the PO pulled it out to disable the system.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #9 of 9 Old 09-10-2010, 01:04 PM
nlynd1978
2006 XK Commander
Clean the sensors and check the wiring as well. They could be dirty and/or damaged causing the light to come on.
Also i would not disable the system on purpose. As i learned this watching a friend deal with it. He disabled the abs on his car so he could race the car (he was also learning to drift). He got into an accident. Insurance company inspected the car, and found the ABS disabled. They refused his claim. Hes paying for a car he doesn't have any more cause of it. Mind you his accident was not from racing. Rear ended some one last winter in the snow due to loss of control when he locked his brakes on the icy road. Totaled his car and the other persons with both of them in the hospital.
Also a working ABS and SRS system are great insurance discounts, being as insurance for and 18 yo kid is expensive.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
Anti Lock Brake Code 30....which part is this exactly?? jlcca844 ZJ Grand Cherokee Forum 8 12-01-2009 08:56 AM
Anti-Lock Brakes steve L. ZJ Grand Cherokee Forum 14 03-08-2009 11:06 AM
Anti-Lock Brakes steve L. ZJ Grand Cherokee Forum 4 12-17-2008 08:41 PM
anti lock brake light problem redjeepcherokee ZJ Grand Cherokee Forum 3 01-20-2008 06:20 PM
Anti-Lock Brakes engaging rossj711 ZJ Grand Cherokee Forum 2 01-21-2006 12:38 PM
