ABS module repair with pics - Page 2 - JeepForum.com
 2Likes
post #16 of 32 Old 02-24-2013, 07:34 AM
ZeeJay1997
I thought you were paying me back for poking at you about buying a scan tool.
The light has been on about 4 years. I'll keep tinkering with it until i figure it out.
ZeeJay1997 is offline
post #17 of 32 Old 07-15-2013, 08:49 PM
webhostingdesig
Is there a service that will do the resoldering for a fee and ship it back to you?
webhostingdesig is offline
post #18 of 32 Old 10-10-2014, 06:19 PM
Dukenukemx
1997 XJ Cherokee
Can someone help me, I'm in a bind. I removed my ABS mobile and cut it open to fix the problem. And yea it was the solder joint. Problem is my screw driver slipped when I was trying to pry it open and broke this component on the circuit board. It knocked the cover straight off of whatever it is. That's the problem I have no idea what it is. If anyone knows what it is or can read me the information off theirs that would help me a lot.
I think it was a relay of some sort.
97 Jeep Cherokee Sport - Custom cone air, exhaust header, KYB, custom Stereo, 2.5 inch Rear lifted
98 Jeep Grand Cherokee - Custom cone air, exhaust header, KYB
Dukenukemx is offline
post #19 of 32 Old 10-10-2014, 06:25 PM
ZeeJay1997
the board is broken (unrepairable IMO) so bet thing to do would be punt.
try your luck in the junkyard
Edit: nevermind
post #20 of 32 Old 10-10-2014, 06:28 PM
ZeeJay1997
on second zoomed in look, that appears to be the edge of the conformal coating. And it looks like a solder joint is broken on whatever that is is the upper left hand corner
post #21 of 32 Old 10-10-2014, 06:41 PM
zjosh93
That sure looks like the base of a surface mount relay. What happened to the rest of it? Any numbers or markings on the broken part? You can usually find those parts online but some of the old electronics are out of production.
zjosh93 is offline
post #22 of 32 Old 10-10-2014, 06:49 PM
ZeeJay1997
i was going to guess a rectifier but idk
if you can figure it out, you need to fix this
post #23 of 32 Old 10-10-2014, 06:51 PM
ZeeJay1997
and maybe these too
post #24 of 32 Old 10-10-2014, 07:14 PM
zjosh93
I think he was talking about this. Just looking at the video in the original post it had a black cover with markings but the video quality isn't good enough to make it out. Can't find any better pictures of it googling. Without that part your looking at a junkyard module anyway.
zjosh93 is offline
post #25 of 32 Old 10-10-2014, 07:35 PM
Dukenukemx
1997 XJ Cherokee
Yep, that's the thing I'm talking about. I was able to find a video of someone holding it with their hands but I can't make it out. Tried talking to someone from Digikey and the photo is too terrible for them. Plus they kept hampering me about how I'd never get it off, even though I already did. Tin foil surrounding the area and a heatgun on it for 30 seconds allowed me to pull it off. But I still need a replacement.
post #26 of 32 Old 10-10-2014, 07:39 PM
Dukenukemx
1997 XJ Cherokee
Here's the area with the component removed.
post #27 of 32 Old 10-10-2014, 07:56 PM
Dukenukemx
1997 XJ Cherokee
HURRAY! I found the plastic cover for it. It was sitting in the dirt at night so I must have gotten lucky.
*UPDATE*
Digikey person thinks it's a crystal or an oscillator with a frequency of 15.9MHz but they don't have it, and it's a guess. He maybe onto something cause the underneath looks like this.
post #28 of 32 Old 10-10-2014, 08:17 PM
zjosh93
That's some good detective work duke. Too bad DigiKey didn't have any, they are my first source for electric parts. Just googling 15.9 mhz oscillator came up with a few hits but not on any websites I can recommend.
zjosh93 is offline
post #29 of 32 Old 10-10-2014, 08:26 PM
Dukenukemx
1997 XJ Cherokee
Thanks, but next is to try a forum like badcaps.net. These ABS modules cost $100 or more, so a $5 part seems worth trying. I'll see what local junk yards want for them tomorrow.
post #30 of 32 Old 10-26-2014, 08:41 AM
rjfjr
Really helpful thread, thanks for starting and the ongoing contributions. I've confirmed my pump is still good and have removed the module (ATE pn 56027931) which looks just like the one in the video on the inside....i just can't tell what to do next. The solder points on the power and 4 pump pins don't look cracked or bad. I'm not getting any audio on the video, so can't tell if i'm supposed to scrape them and then resolder or what....any advice greatly appreciated. Should I be able to see an obvious fault on the board?
RJ
rjfjr is offline
