ABS module repair with pics - JeepForum.com
 2Likes
post #1 of 32 Old 01-21-2013, 03:32 PM Thread Starter
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I know most of the jeep forum hate ABS but I like to have stuff thats supposed to work working. This project has been lurking for a long time and I knocked it out finally. I needed the ABS to work because when I rip the steering and suspension out to replace them{brakes included} I need to be able to use the DRB to bleed the brakes if I get air in the HCU. I had pulled a CAB out of a junkyard ahead of time and resoldered the motor connections on the board as in this video.
First as always disconnect the negative battery terminal. Pull the washer tank and tie it out of the way,2 10mm screws. Pull the airbox,3 13mm screws. This will give you room.
Pull the three nuts that hold the HCU brackett down. The lower stud has two nuts on it. The first holds on the steering box cover,the second one below that holds on the lower leg of the brackett.
Pull the tab release handle on the main CAB connector towards the firewall. This will unlock the connector and allow you to pull the connector straight up.You may to wiggle it a bit but don't get carried away. It has small pins it is not unlike the pcm pins and too much force will result in loose connections. Also, you may have to use a small screwdriver to gently pry that release handle out all the way. In the upper right hand corner you can see the HCU motor connections. Squeeze the sides of the connector and pull up.
The harness is held on to the body by two of these. Squeeze the ends together and pull them out of the body holes. This will allow you to get the harness somewhat out of your way.
At first I tried to take the 4 4mm screws out that attach the CAB to the HCU without releasing the CAB from the HCU brackett. With a 1/4 drive socket wrench I got 3 of them out.The right rear one was impossible for me to get.Its easier to remove the 3 13mm screws that hold the HCU to its brackett loose, cause it gives you wiggle room to get to that 4th screw. The lines have some spring to them but don't get carried away. Remove the brackett before trying the 4th screw. Tie off the HCU/CAB to support it so its weight doesn't rest on the lines.
Pic of three of the 4mm screws that hold on the CAB to the HCU. Do yourself a favor and put a piece of tape over the hole at the bottom of the coil tower. Guess where the 4th screw went? Luckily I had an extra.
It was pretty nasty in there so I broke out the purple power and degreased and painted after masking some stuff off.
Put it all back in and in the next post I'll show you the result.
Originally Posted by HighLonesome
coralman is offline
post #2 of 32 Old 01-21-2013, 03:36 PM Thread Starter
coralman
coralman's Avatar
ABS repair PART TWO
After getting it all back together I plugged in the drb ran the HCU motor and tested for codes. She's good to go. Test drove and I now have ABS again.
coralman is offline
post #3 of 32 Old 01-22-2013, 03:34 AM
KoreaZJ
1994 ZJ
Nice!
for sharing the pics and write-up!
KoreaZJ is offline
post #4 of 32 Old 01-22-2013, 03:47 AM Thread Starter
coralman
coralman's Avatar
Thanks Korea. I am just the apprentice OBI-WHAN,lol.
coralman is offline
post #5 of 32 Old 02-08-2013, 02:35 AM
webhostingdesig
my mechanic says:
"4009-hydraulic pump circuit - there is power to the pump, and when commanded on, it will not run, the motor is shorted/open and needs replaced"
can this be fixed by working/replacing the module or do i need a $1200 pump?
webhostingdesig is offline
post #6 of 32 Old 02-08-2013, 04:10 AM Thread Starter
coralman
coralman's Avatar
I would give it a shot before going for the big bucks. Just brush up on your soldering skills. Remember the vid is for a specific controller made by Teves, mopar #56027831. Most likely, the two solder joints that connect to the two motor pins on the board are bad. Take your time, a mini hacksaw will seperate the case, dont cut too far. Most recently I used a plastic welder from HF to break the glue bond and maintain more case integrity. I epoxied the case back together when complete and sealed the gap with rtv.
Dan_in_MN likes this.
coralman is offline
post #7 of 32 Old 02-08-2013, 04:19 AM
ZeeJay1997
Originally Posted by webhostingdesig View Post
my mechanic says:
Most likely the board rather than the pump.
You can confirm this by disconnecting the two pin connector and applying battery voltage to the pins. If the motor runs when powered up directly, you do not need a motor.
Nice write up btw, I had missed it somehow.
ZeeJay1997 is offline
post #8 of 32 Old 02-08-2013, 05:02 AM Thread Starter
coralman
coralman's Avatar
Thanks,Zee!
coralman is offline
post #9 of 32 Old 02-23-2013, 01:35 PM
ZeeJay1997
Changed out the ABS module this AM. Still have ABS lamp on. Took it out and did some 15 MPH stops so the module could see the sensors, no help.
My old module was giving a pump circuit failure, so I wrung all of those circuits out... all good. Connected pump straight to battery... it ran.
Any ideas besides reading the codes?
post #10 of 32 Old 02-23-2013, 07:16 PM Thread Starter
coralman
coralman's Avatar
Well damn, sorry Zee. I gave it a shot. As soon as I find a reasonable price on a case I'll send ya the koolaid if you want,lol.
coralman is offline
post #11 of 32 Old 02-23-2013, 07:24 PM
ZeeJay1997
LMAO.. touche'
post #12 of 32 Old 02-23-2013, 07:46 PM
ZeeJay1997
Today when I was working on it I was pondering the effects of a cracked header on the ABS module. Then I thought about your heat shields. Probably would be a good candidate for a precautionary mod... if the damn thing worked...
post #13 of 32 Old 02-23-2013, 08:17 PM
4Slow9erHybrid
Where did you get the replacement module? Was it re-soldered? If you just got one from the junkyard, it's likely to have the same issue. I know this from experience.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #14 of 32 Old 02-23-2013, 08:42 PM
ZeeJay1997
Originally Posted by 4Slow9erHybrid View Post
Was it re-soldered?
Yes it was resoldered. I need to do some more troubleshooting. I may have a spread pin on the connector.
I'm wondering if it the HMU being inactive all this time has anything to do with it.
post #15 of 32 Old 02-24-2013, 05:08 AM Thread Starter
coralman
coralman's Avatar
I was serious, but the only one I am seeing at the moment is $ 137.00 which seems steep to me. Mine was dead for over a year, but worked when I installed the resoldered one. I know of another in a local yard that I have to go get a BCM out of to match the PCM I already pulled {unalarmed}. I'll get it and have another go. At my yard they see me so much its cheap.
coralman is offline
