abs light stuck - JeepForum.com
post #1 of 7 Old 05-28-2003, 01:38 AM Thread Starter
scubatch2
abs light stuck
After a week long trip to MOAB,my ABS light on the dash is stuck on.It came on on day one and has never gone off since.Anyone have any idea how to fix. Thanks
95 zj 5.2,Re 4.5+3/4in spacer,456's,true-trac frt,trac-lock rear,Hanson rockers,33"MTRs,surco,hella's,high-lift,flow-masters&cat,ax&shovel mounted on rack,onboard air,231 swap,Hanson front & rear bumper,ford elec fan
- jeff-
scubatch2 is offline
post #2 of 7 Old 05-28-2003, 03:59 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I've got the same problem. I actually had one guy tell me just to pull the lightbulb.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 7 Old 05-28-2003, 06:02 AM
pHaZe5unIt1
mine will flicker everyonce in while:shrug:
2004 wrangler 2.4L
pHaZe5unIt1 is offline
post #4 of 7 Old 05-28-2003, 06:10 AM
Jillie
Jillie's Avatar
i noticed mine turned on for awhile on a 16 hour drive to Florida from Ohio and on the way back.............when i would get to a "pit stop" i just turned my ZJ off and sometimes it would be gone,.......it doesnt do it now though
Jillie is offline
post #5 of 7 Old 05-28-2003, 08:19 AM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
I thought when the ABS light stays lit after ignition, there was a problem with your ABS system?
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
post #6 of 7 Old 05-28-2003, 10:56 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sonar,
you are so correct. I no longer have ABS.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 7 Old 05-28-2003, 03:02 PM
pozner
Mine's a '94 and the ABS light stays on, too. The PO (previous owner) said he noticed it after a brake job was done, but he never took it back so the mechanic could check it. He said he thought the ABS was working. Book says if the light stays on, it's not working.
There is a section in the Haynes repair manual that shows where the sensors are located, and how to check it out. I'm in no particular hurry to fix it because of more important problems, but at least the info is there whenever I finally get to it. You may luck out and only have a broken sensor wire.
Poz
pozner is offline
95 grand cherokee od light stuck in third terry3blue ZJ Grand Cherokee Forum 22 01-08-2014 07:25 PM
Part-Time light stuck ON WXman ZJ Grand Cherokee Forum 1 10-26-2009 07:44 AM
Stuck Hatch and back light out. MarxZies ZJ Grand Cherokee Forum 3 07-05-2009 12:50 PM
got stuck, engine light appeared chad2616 WK Grand Cherokee & XK Commander Forum 7 03-01-2009 06:47 PM
Emergency Brake light stuck on? Kcolg ZJ Grand Cherokee Forum 6 06-16-2006 11:22 PM
