ABS light just comes on? - JeepForum.com
post #1 of 5 Old 06-01-2004, 07:59 AM Thread Starter
shelter1
ONly after an hour or so driving on the highway, I'm guessing its getting hot??? After you let it sit and crank it back up no light???
97 4.0
shelter1 is offline
post #2 of 5 Old 06-01-2004, 11:05 AM
RufftyTuffty
RufftyTuffty's Avatar
97 4.0
Probably a faulty sensor....you could check the ohm reading for each...if you can do that...or simply get some new sensors and swap them out.
Also, HP hose the ABS tone ring on the inside of the wheel...if you go offroad this gets muddy and will also trip out the ABS system.
97 V8 TSi 7" RK LA/36s/4.88s/ARBs/TERA 60/8.8/Crane/PSC
RufftyTuffty is offline
post #3 of 5 Old 06-02-2004, 05:29 PM
willsellout
I have the same problem..it comes on sometimes..nothing happens..I think it's just sensor problems as my brake lights sometimes stay on after I shut it off as well..I am just gonna replace em when I feel like it..no big deal.
Dan
willsellout is offline
post #4 of 5 Old 06-05-2004, 12:48 AM
DuneCrawler
ABS Light
Hi there, just joined!
I have a '98 Laredo. (only got it 2 months ago).
My ABS light also came on at times. I spoke to the previous owner, and he said it's been doing that for the last 5 years! The dealer replaced the rear sensors twice - no change. They eventually gave up and told him to live with it or sell the car!
This weekend I was determined to find it, so I started from the back working forward with a multi-meter.
Check the connection underneath the rear seat. Two wires each. One black and one red connector. These had a bad connection. To check: Start the car and then handle the wires/connections, you will probably see the light come on. I just opened the connectors and squeezed them a bit closed for a better connection. I did not want to solder them together as I do not know how sensitive the system is.
I hope this works for you.
DuneCrawler is offline
post #5 of 5 Old 06-06-2004, 11:57 PM
kentman
kentman's Avatar
2006 XK Commander
Photos?
My ABS light used to come and go. Now it is on all of the time. If the problem is this simple, then I will give it a shot. Reconnection of a few wires is not a big deal.
ABS is not that important to me. It is nice to have, but it is not the end of the world if it is defaulting to non-ABS braking. I have not yet locked up the wheels with the ABS light on.
Kent
kentman is offline
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 12:29 AM
OIL LEVEL GAUGE, AIR BAG LIGHT & ABS LIGHT SHOWING ON DASHBOARD - WJ Model babix0ashh ZJ Grand Cherokee Forum 6 01-19-2010 12:48 AM
gcl 4.0 driving light/brake light/turnsignal issues msherman1 ZJ Grand Cherokee Forum 1 01-05-2010 09:23 PM
Super cheap headlight, marker light, directional light kit... thoughts? aaron7 ZJ Grand Cherokee Forum 13 01-07-2009 06:17 PM
Tail Light and Instrument light problem t_guenther ZJ Grand Cherokee Forum 0 09-18-2008 07:27 AM
