ABS light on 1998 Grand Cherokee - JeepForum.com
post #1 of 3 Old 01-22-2009, 10:59 PM Thread Starter
grapeman
Just purchased a 1998 Grand Cherokee. 113,00 miles. The abs light was on. Ran a code and it said pump failure. Determined pump motor was not running. Checked fuses, both good. Took motor off of pump and it was kinda hard to turn. Rotated it by hand a few times and it freed up. Put current to it and it ran fine. Put it back on the pump and no go. Any suggestions on where to go from here?
grapeman is offline
post #2 of 3 Old 01-22-2009, 11:42 PM
waarp8nt
Check to see if there is power and ground going to the motor. You may have to have a helper pump the brakes as you check for power and ground.
waarp8nt is offline
post #3 of 3 Old 06-02-2009, 02:33 PM
chrisbean
This MAy not work for you, did for me though.Not even sure if it had anything to do with ABS but my light came on one day after I did my front brakes. It would go off and on over the next 2 years. I never checked any codes or anyhting since they seem to work fine. Then I did my rear brakes and decieded to do the parking brake to since I had it for 5 years. After I di the park/rear brakes and tightened up the park linkage the light went of? (at the time it had stayed on for about 5 months straight). Not sure IF that helped it or not but it seemed to work for me.
chrisbean is offline
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 07:11 PM
1998 Grand Cherokee T/C questions Warmbolds ZJ Grand Cherokee Forum 6 10-26-2009 09:20 PM
Help for a 1998 Grand Cherokee TSI lori2stj ZJ Grand Cherokee Forum 11 01-05-2009 12:06 AM
1998 Grand Cherokee fog light question scatterdragon ZJ Grand Cherokee Forum 5 05-25-2006 03:41 PM
Removing front corner light 1998 Grand Cherokee rjacb ZJ Grand Cherokee Forum 3 09-11-2005 02:33 PM
