ABS light on - JeepForum.com
post #1 of 13 Old 08-16-2005, 10:15 AM Thread Starter
kemicalburns
ABS light on
My Abs light has come on twice after driving thru an area were the speed limit is 20mph and requires some occasional stops for pedestrians. the first time i stoped down the road and turn the engine off for about 2mins then restarted and the light stayed on till we actually parked for an hour or more. it stayed off till sunday when driving thru the same area. I am not sure if it will stay off because i have not driven it since. would there be a code generated from this. my brakes are pretty new with rotors an calipers. any thoughts?
98 limited
5.9ltr
stock
2.5" exhaust flowmaster
kemicalburns is offline
post #2 of 13 Old 08-16-2005, 10:35 AM
mr_user
Check for something easy first, like the ABS relay. It is located in the PDC on the passenger side of the motor.
Or you can just do what I did, and disconnect the ABS altogether..A new module is going to run you some big bucks if that's the case.
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #3 of 13 Old 08-16-2005, 10:41 AM
ExplorerDMB
ABS Modules are indeed expensive. A new module for a BMW we had in the shop one day was around $1,000 uninstalled.
-Drew
- '92 Laredo 4x4
- '00 XLT 4x4 7" Lift, 4.56s, LSD, 33's
ExplorerDMB is offline
post #4 of 13 Old 08-16-2005, 11:52 AM Thread Starter
kemicalburns
jive bmw's. i would hope its not that either
98 limited
5.9ltr
stock
post #5 of 13 Old 08-16-2005, 12:48 PM
greasefingers
greasefingers's Avatar
1994 ZJ
You should at least inspect the sensors. During the brake job it is very possible that one of the got bumped and is not exactly aligned with the sprocket.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 13 Old 08-17-2005, 08:39 AM
rschunk
rschunk's Avatar
ABS light on
Yep, had the ABS light on my old '97...stealer said the pump was bad and quoted me $560.00 just for the part. Never did get it fixed and traded for a 2002.
OTOH, I had the same light on my 93' GC after doing some 'mudding'. Figured it was mud so I used the high pressure wash to clean off the rear of the wheel and the connecting parts and the light went off.
I'd check for a bad connection. Don't know if it throws a code as I didn't know how to 'discover codes' then, but it probably does.
Good luck....
"Mean Green"
4.0 inline 6
3" BDS Suspension lift
ARB bumper with
T-Max 9000# Winch
Optima Yellow
JKS Swaybar Quick Disconnects
30x9 Dunlop Mud Rovers
Rocky Road Rockrails (Great rails, lousy shipping)
GPS Street Pilot
175,000 miles & still going!
93 Green GCL
Green Jeep Club Member #163
check out the pictures..
Also a 'Graphite' 2002 Grand Cherokee Laredo. Graphite Jeep Club Member #1
rschunk is offline
post #7 of 13 Old 08-17-2005, 10:15 AM Thread Starter
kemicalburns
well i drove it yesterday mostly hwy and the light never came back on. so it is probably a loose connection some place. will check it out this weekend
98 limited
5.9ltr
stock
post #8 of 13 Old 08-17-2005, 05:31 PM
jdpaysnoe
Mine goes on and off all the time. Along with my security light and my check engine light. I have tried to pull codes on all the blinking lights, but their are no codes so I have a feel its just a loose connection somewhere. I think the wiring on my whole Jeep is in shambles, but it still runs well and the thing is a bucket at this point anyways so I dont really care about it.
Jeremy
-2" Budget Boost
-31" Pro Comp All-Terrains
Heavy Duty Adjustable Track Bar
-Okie Custom Antenna Mount
-Old Man Emu Steering Stabilizer (From
jdpaysnoe is offline
post #9 of 13 Old 08-18-2005, 07:45 AM Thread Starter
kemicalburns
im gonna stray a little hear, my jeep got broke into last weekend. nothing was stolen but they busted the right rear passenger side wing window . my alarm of course went off when they tried to open the door . what im wondering is why didnt jeep install a blinking light someplace on the 98 5.9ltd. i would bet the jeep wouldnt have even been touched if there was a light letting them know there was an alarm. Since there isnt one how would i go about installing one and have it only come on when the alarm is active?.
thanks
98 limited
5.9ltr
stock
post #10 of 13 Old 08-18-2005, 06:35 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
thanks
My security light blinks, but that's only in the dash.
Back to the original question, I think many Jeeps out there have Gremlin's built in that can cause confusion and frustration. My 99 WJ had several, so I got rid of it, interestingly enough, the 94 with tons of miles, has very few if any. HMMM....
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #11 of 13 Old 08-19-2005, 03:56 PM
rschunk
rschunk's Avatar
ABS light on
You could always get one of those little blinkers that bike riders wear. Stick it on the dash and turn it on when you get out....cheap fix...
"Mean Green"
4.0 inline 6
ARB bumper with
T-Max 9000# Winch
Optima Yellow
GPS Street Pilot
93 Green GCL
rschunk is offline
post #12 of 13 Old 08-19-2005, 03:57 PM Thread Starter
kemicalburns
thought about that. im just suprised mine doesnt have one unless its under the dash cover. never had it off but will look tonight just incase
98 limited
5.9ltr
stock
post #13 of 13 Old 08-19-2005, 04:04 PM
greasefingers
1994 ZJ
I added a blinking LED to my dash. I got it at radio shack. I power it with two AA batteries.
Cheers Steve
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 12:29 AM
OIL LEVEL GAUGE, AIR BAG LIGHT & ABS LIGHT SHOWING ON DASHBOARD - WJ Model babix0ashh ZJ Grand Cherokee Forum 6 01-19-2010 12:48 AM
gcl 4.0 driving light/brake light/turnsignal issues msherman1 ZJ Grand Cherokee Forum 1 01-05-2010 09:23 PM
Super cheap headlight, marker light, directional light kit... thoughts? aaron7 ZJ Grand Cherokee Forum 13 01-07-2009 06:17 PM
Tail Light and Instrument light problem t_guenther ZJ Grand Cherokee Forum 0 09-18-2008 07:27 AM
