ABS Light - - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > ABS Light -
Income tax season is upon us. We got what u needRough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 08-09-2011, 03:43 PM   #1
jehworks
ABS Light -
I replaced my exhaust manifold this weekend and now my ABS light is one, i've been searching around for solutions - and found that it could be a wheel speed sensor. Does this sound reasonable and how do I replace it?
jehworks is offline   Reply With Quote Quick reply to this message
Unread 08-09-2011, 04:19 PM   #2
MeanGreenZJ
It could be one of the four wheel speed sensors or it could be something else. If you're not going to run diagnostics on it, your guess is as good as anyone's.
MeanGreenZJ is offline   Reply With Quote Quick reply to this message
Unread 08-09-2011, 05:29 PM   #3
onevision
Yeah, it could also be your ABS chip, which is expensive enough that it's not even worth replacing. Without a DRB scan tool though, it's near impossible to know. Your Jeep dealer should be able to plug in and tell you and not charge you for the diagnostic, since it takes all of five minutes to do.
98 ZJ - custom double triangulated rear and 3-link front with 6 1/2" lift on 33"x13.5" and Teralow gearing
Wrenching pics at (slow connection) http://onevisionbeyond.com/gallery/v/jeep/
onevision is offline   Reply With Quote Quick reply to this message
Unread 08-09-2011, 06:18 PM   #4
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
The #1 rule of diagnostics in a case like this, (system "A" works, worked on unrelated system "B", now system "A" no longer works), is to go back and look at anything that you may have disturbed while doing your work. 99.99% of the time, you did... coincidences are rare.
Take a look at where the wires come out of the ABS module. Look at the wheel sensors. Maybe the jack stand crushed something, as an example.
Go back over the work you did, and look at any components associated with the ABS that may be nearby, and you will hopefully find the problem.
Unless you live in OZ, the Jeep dealer will do nothing for free.
Good luck.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline   Reply With Quote Quick reply to this message
Unread 08-09-2011, 10:08 PM   #5
jnicewan
There is a 2-wire connector right by the ABS module, or right beside the intake manifold. This connector is for the ABS. I have accidentially unplugged it while working around the intake and a broken motor mounted pulled it apart once too. This is just a guess though since you were right in that area
jnicewan is offline   Reply With Quote Quick reply to this message
Unread 08-10-2011, 10:29 AM   #6
onevision
Man, your Jeep dealer sucks then. I've taken my Jeep to them many times to have them plug their $12,000 DRB scan tool in and tell me the results. They've given me great advice and insight into countless problems and never with a charge, unless I had them do some work.
For me, my ABS light randomly came on after working on the transfer case (so, pretty unrelated). It ended up being that my chip failed, but a replacement was in excess of $800. The dealer later found a place that repairs chips in Washington for around $200, but honestly I could care less about having ABS or not. Still can stop on a dime, and ABS does nothing for ice - at least not the ice I deal with each winter.
Unread 08-10-2011, 10:39 AM   #7
NightmareTsi
My abs light is on too but I dont really care. Im not much for the abs crap.
NightmareTsi is offline   Reply With Quote Quick reply to this message
Unread 08-10-2011, 11:42 AM   #8
Corrupt
I had a car one time that the ABS light came on. I drove it for quite a while before I actually thought to look at the fuses. In this particular car there was a fuse under the hood that was blown. It provided power for the ABS. After replacing this fuse my ABS light went out and all was good.
So if your ABS light is on. Check all your fuses first before assuming it is something expensive.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline   Reply With Quote Quick reply to this message
Unread 08-10-2011, 12:12 PM   #9
MeanGreenZJ
Who needs ABS anyways, better off doing some cool mods like a cold air intake or a fart-can muffler. Maybe even some led tail lights.
Unread 08-11-2011, 01:22 PM   #10
onevision
I agree, can't say I ever noticed better braking when my ABS light wasn't on. I just ended up pulling the light out of the dash, as I was tired of looking at it on and had no intention of buying a new chip.
Unread 08-11-2011, 01:48 PM   #11
Midnightluckey
Mine started acting up and kicking in all the time, and since it doesn't ever snow or even ice up here, i disabled it, since it isn't all that important to me. If I had to drive on ice at all I'd really want it working.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline   Reply With Quote Quick reply to this message
Unread 08-11-2011, 09:09 PM   #12
KennzX
Just for kicks, check your fluid, if it looks just a little low add abit of fluid, see if that does anything, solved my ABS light.
Jeep, The dirtiest of the four-letter words
Not stuck; temporarily detained
KennzX is offline   Reply With Quote Quick reply to this message
Unread 08-14-2011, 11:01 AM   #13
jehworks
ABS Module Fixed
Thanks for the suggestions, turns out it was the cable was disconnected.
Unread 08-15-2011, 12:20 AM   #14
onevision
LOL The simplest answer is usually the correct one.
ABS light , brake , speed sensor
