abs delete - JeepForum.com
post #1 of 17 Old 08-10-2009, 11:43 PM Thread Starter
nwfjarhead
abs delete
whats involved? I have a 94zj5.2 is it just a matter of fabbing up some lines in place of the abs pump and removing the control module?
nwfjarhead is offline
post #2 of 17 Old 08-11-2009, 12:24 AM Thread Starter
nwfjarhead
***bump***
post #3 of 17 Old 08-11-2009, 12:25 AM
WhiteOut
WhiteOut's Avatar
You bump after 40 minutes on a Monday night at 11PM MST?
WhiteOut is offline
post #4 of 17 Old 08-11-2009, 01:02 AM
SIU
If all your wanting to do is disable the abs, Just pull the main fuse. I did that on my 95 several years ago. It annoied the crap out of me, seemed like the least degrade in traction would set it off. I dont miss it.
SIU is offline
post #5 of 17 Old 08-11-2009, 02:55 AM
eshew
Yep, pull the fuse... no more ABS.
eshew is offline
post #6 of 17 Old 08-11-2009, 11:20 AM Thread Starter
nwfjarhead
I know I can pull the fuse but that wont allow me to bleed the fluid out of the abs pump.
post #7 of 17 Old 08-11-2009, 11:30 AM
ZJJAMES
why do you want to do that?
ZJJAMES is offline
post #8 of 17 Old 08-11-2009, 11:34 AM Thread Starter
nwfjarhead
why do I want to bleed the system?
post #9 of 17 Old 08-11-2009, 12:11 PM
ZJJAMES
ya why do you need to get the fluid out of the abs pump
ZJJAMES is offline
post #10 of 17 Old 08-11-2009, 09:19 PM Thread Starter
nwfjarhead
so I can bleed the ENTIRE system. brake fluid breaks down just like any other fluid. if it doesn't get changed periodically it will cause problems like calipers sticking. the reason I want to get rid of the abs is mainly because of the off road effects. I would rather have full control weather on or off road.
post #11 of 17 Old 08-11-2009, 09:27 PM
WhiteOut
WhiteOut's Avatar
What offroad effects do you mean? I have never had issues with ABS offroading.
WhiteOut is offline
post #12 of 17 Old 08-11-2009, 09:34 PM Thread Starter
nwfjarhead
I've had them keep me from stopping in loose dirt many times and just this past weekend it almost made me run into a culvert.
post #13 of 17 Old 08-11-2009, 09:35 PM
coonash
coonash's Avatar
Bleed it, then pull the fuse
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #14 of 17 Old 08-11-2009, 09:39 PM Thread Starter
nwfjarhead
cant bleed it without a scan tool. even if I could the question asked was what all does the abs consist of and is running the new lines and removing the pump and control box all there is to it. I know I can pull the fuse but I figured if I am NEVER going to use the abs again weather on or off road why not pull it and maby someone who needs it can get it rather than havein to pay the insane dealer prices for a abs pump.
post #15 of 17 Old 08-12-2009, 06:52 AM
kentman
kentman's Avatar
2006 XK Commander
Pulling it is time wasted. Save your energy for something more useful.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
Muffler delete on 4.0 PaLftr ZJ Grand Cherokee Forum 10 02-10-2010 07:59 PM
EGR delete , can I do it ? newfieZJ ZJ Grand Cherokee Forum 9 07-19-2009 10:13 PM
Bumper Delete WarHog38s ZJ Grand Cherokee Forum 70 02-15-2009 05:53 PM
CEL Delete? Jimmer ZJ Grand Cherokee Forum 4 09-28-2007 07:57 AM
