ABS delete? - JeepForum.com
post #1 of 7 Old 12-14-2010, 08:59 PM Thread Starter
Spike300
ABS delete?
How much more braking would i gain from the removal of the abs. When im talking removal, i say everything. The pump, module, sensors the works. What would the best way to remove the crap from the engine bay, and plumb new lines?
5.2-242 tcase-44a-30x9.50x15 MT/R-American Racing Burst Rims -Optima -E3 plugs-Custom Paint-Amsoil-Addco Front and Rear-polyurethane bushings
To be installed: RE gen2 discos, military battery terminals
To be rebuilt: HP30
To be received:
To be paid for:
Next on the list: complete redo of brakes and
lines
Needed: fittings, coil of brake tubing, Russel speed bleeders
Zombie Outbreak Response Unit #75
Spike300 is offline
post #2 of 7 Old 12-14-2010, 09:09 PM
Coolcatracing
Plumbing new lines can be a PITA. The brakes won't perform much better without it. I've deleted several abs setups in our race cars and replaced most with factory non abs lines but plumbed some myself. None of them really gained much. They had slightly better feel at the limit but power and capacity remained about the same. In a jeep feel at the limit isnt as important and the weight savings won't do much. I'm not sure if the jeep system is split in the abs motor or not but most are. If not you need to look into a proportioning valve as well.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #3 of 7 Old 12-14-2010, 09:14 PM
tonymartin
Why not just pull the fuse for the pump if you don't want the ABS. Should have the same effect as removing everything, shouldn't it?
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #4 of 7 Old 12-14-2010, 09:38 PM
Zachs
What do you plan on gaining? ABS doesn't kick in until you're past a certain speed anyway and even then, I've yet to see it not help. And I'm a huge fan of non-ABS systems.
2000 Sahara TJ
1997 Limited ZJ
Zachs is offline
post #5 of 7 Old 12-14-2010, 09:52 PM
Coolcatracing
Some systems are horrible and honestly add stopping distance, I haven't really had to use the abs on the jeep so I'm not sure how well it works. I don't have the same requirements though for it as I do with the race cars.
post #6 of 7 Old 12-14-2010, 09:57 PM
AlphaLorde
I am going to get in trouble one of these days for posting other sites but just trying to be helpful
This is my plan
ABS System Delete - MallCrawlin.com Forums
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #7 of 7 Old 12-17-2010, 07:24 PM Thread Starter
Spike300
Im looking to gain whatever better braking i can. And clearing up room in the engine bay. Who has done this and how much did you gain? braking wise
To be rebuilt: HP30
To be received:
To be paid for:
lines
Spike300 is offline
abs delete nwfjarhead ZJ Grand Cherokee Forum 16 08-13-2009 06:05 AM
EGR delete , can I do it ? newfieZJ ZJ Grand Cherokee Forum 9 07-19-2009 09:13 PM
CEL Delete? Jimmer ZJ Grand Cherokee Forum 4 09-28-2007 06:57 AM
