ABS control unit, where do I get one that's not $1000 and WORKS? - JeepForum.com
 2Likes
  • 2 Post By StPaul59
post #1 of 7 Old 09-22-2017, 02:00 PM Thread Starter
zace
I have replaced my ABS control unit, and regrettably tossed the original unit, with a pulled part. The dealership said the reprogramming did not take. I pulled another part and didn't notice till I was ready to install it that the wired were corroded and awful looking. Then I caught the part numbers on both these parts are NOT the same as the mopar part number listed. The barcode shows 52009047 on the 1st pulled part and P052009240AC when Mopar lists it as
52009047 . Are there different part numbers on different 98 ZJ 4.0L?
I have a 98 ZJ 4.0L 4x4 laredo, I hear its a model later in the year of 98 due to it having some different parts like u-joints on all 4 wheels instead of CV joints.
Where do I get an ABS control unit that works and doesn't cost $1000? and before someone says go without because its an off-road vehicle I want ABS for winter and you know stupid drivers making me slam my brakes in town.
zace is offline
post #2 of 7 Old 09-25-2017, 12:55 PM
monte350
if you are worried about stopping distance, it always feels like the ABS makes the stopping distance longer to me than shorter. but these are my first ABS equipped vehicles.
1995 Cherokee(XJ)-Rolled it
1998 Grand Cherokee(ZJ)-Sold it
1997 Grand Cherokee(ZJ)-DD
monte350 is offline
post #3 of 7 Old 09-25-2017, 05:45 PM
AVR2
ABS isn't about making stopping distances shorter, it's about preventing the brakes locking up during emergency stops and allowing you to maintain steering control.
AVR2 is online now
post #4 of 7 Old 09-25-2017, 11:40 PM
Timo_90xj
Timo_90xj's Avatar
A properly functioning ABS system will actually also shorten the stopping distance, apart from locking up brakes on something like a dirt road or heavy snow where the pile-up of sand or snow in front of the tires causes extra friction and reduces stopping distance.
However, as AVR2 mentioned, the primary function of the ABS is to prevent wheel lock-up, which in turn prevents you from spinning around if there's uneven friction under the tires, and to be able to steer.
Not one single person in this planet of earth can modulate standards brakes in a panic- situation well enough to do the job even closely as well as ABS system does.
As for the ABS HCU, your options are to get a new one from Mopar, or hope for good luck with a junkyard unit. I'd look for one from a crashed vehicle.
ABS unit does not need to be programmed to your vehicle, just get one that has the correct part number, install it, and have a jeep dealership do am ABS brake bleed with the DRB3 tool.
***Under construction***
Timo_90xj is offline
post #5 of 7 Old 09-26-2017, 03:42 AM
Kolak
Vendor
Kolak's Avatar
Looks like the current part number for the ABS module for the 1998 ZJ is 56027931AC. They still show as available with a list price of $1165.00. I could give you a huge discount but if it were me I'd try a reputable Jeep salvage yard. Give the people at jwjeep.com a call.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #6 of 7 Old 09-27-2017, 04:26 PM Thread Starter
zace
Well diving into this mystery of the many part numbers I have found (25094601023 - 56027931AC - P052009240AC) are the ATE part numbers which are stock parts originally on Chrysler Voyager(1998) and my ZJ 98. Apparently I must have pulled a ZJ that was older when I got my first part which is not compatible with 1998. The one I did pull off another ZJ was a 1998 but with the electrical cable practically melting off of it I'm not going to put it on. Ill just go pull a good looking HCU for $70 a pop till I find one that works. I'm kind of limited to this since a $1000 part in NOT an option for me. However the $200 ones I found on the autotekcarparts.com website seem the best pricing I have seen.
Thank you you all for the help.
zace is offline
post #7 of 7 Old 09-27-2017, 09:26 PM
StPaul59
Hopefully the crashed vehicle didn't crash because of the abs unit hehehe!
ROBOTYPHOON and zace like this.
StPaul59 is offline
