Quantcast abs comes on at stop - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > abs comes on at stop
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-29-2008, 02:40 PM   #1
dealer2
I have a 96 g cherokee with 4x4 auto v8.whenyou are almost stopped the abs applies.There are no codes in system.If I drive with scanner hooked up it operates fine.I bled brakes and fluid looks good .I have no history on veh ,my customer bought it used and the problem was already there.Any ideas?
dealer2 is offline   Reply With Quote
Old 03-29-2008, 02:52 PM   #2
speedbullet2
You bled the abs system with a drb tool? if not id try that first may have air bubbles in it i had a similar problem in another vehicle was the abs unit had air in it that normal bleeding wouldn't remove.
1996 Jeep [B]ZJ[/B] [COLOR="Green"]Orvis [COLOR="YellowGreen"]Edition[/COLOR][/COLOR] 5.2L Completely stock with Up Country suspension.
2.25" BB soon to be installed.
_______________________________________________
FUTURE MODS
Trailready front and rear bumpers with winch. Roof rack. KOR light bar with 4 lights. 2 lights, shovel, and a high lift jack mounted to roof rack.
speedbullet2 is offline   Reply With Quote
Old 03-29-2008, 03:26 PM   #3
indept
Are you sure it's ABS & not just warped rotors causing the pedal to pulsate?
2000 WJ 4.0L 42RE 242 TC
152,251 miles & counting
indept is offline   Reply With Quote
Old 03-29-2008, 03:35 PM   #4
speedbullet2
Ive never had the rotors cause a pulsating condition but i suppose it might be possible im no brake expert by any means but thats where i would start is with the drb tool and bleed the abs unit.
FUTURE MODS
Old 03-29-2008, 04:14 PM   #5
indept
Warped rotors WILL cause pedal pulsation
Old 03-29-2008, 04:17 PM   #6
tsconver
Hooligan
tsconver's Avatar
2003 WJ
you work on brakes often??? brake pulsation is almost always warped rotors or run out issues, usually a lower frequency pulsation that is speed sensitive. The ABS pedal pulsation feels nothing like a warped rotor. It is a much faster higher frequency pulsation and is not speed sensitive.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/hh219/benumb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/hh219/benumb55839/jeep/image0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Old 03-30-2008, 12:45 AM   #7
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Gents,
it could also be a bad ABS computer.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 03-30-2008, 12:46 AM   #8
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
A simple way to check that would be to unplug the ABS system and see if the brakes still pulse during deceleration.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Old 03-30-2008, 01:08 AM   #9
ninethreezj
If I may add to what Hunter is saying, I would say that it is a great idea to check the braking system by disabling the ABS system. I unplugged the relay for the exact same issue that you are having (User - Kyle suggested this), and now I have brakes again.
My issue may have been different from yours: as I was rolling at any speed then apply the brakes, all is well until I am at about 10-5 mph; this is when the ABS system makes a loud noise, makes stopping significantly more difficult, then stops really hard. Ultimately, it seemed as though I was stopping on a really slick surface and get that audible ABS sound, then total lock-up.
I have since not plugged it back in; I would not suggest leaving it out forever, as you run the risk of locking up really easily.
Hope this helps.
1993 Grand Cherokee
5.2
QuadraTrac
Stock...Everything
1966 Toyota FJ40 Landcruiser
327 / SM420 / Orion
33" BFG AT
4" Skyjacker Lift
Lockrite (Rear)
ninethreezj is offline   Reply With Quote
Old 03-30-2008, 01:16 AM   #10
speedbullet2
Nah i dont work on brakes and i thought he said it was abs pulsation thats why i recommended the abs unit drb tool bleed anyways good luck on fixing it hope we were of some assistance.
EDIT: On my post about pulsating rotors IMHO i call that a wobble thats why i confused people in saying i never seen rotors pulsating.
FUTURE MODS
Old 03-30-2008, 02:32 AM   #11
AgitatedPancake
Frobot Fabrication
AgitatedPancake's Avatar
the rotor has a wobble which causes a pulse in the brake pedal, but ABS is VERY fast, happening probably near 10 times a second.
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake is offline   Reply With Quote
Old 03-30-2008, 02:43 AM   #12
madrabbitt
abs pulse feels like a vibration then a pulse.
warped rotor feels like a shake
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 03-30-2008, 03:00 AM   #13
Kruzin
It could be a sticking cylinder in one of the calipers/drum cylinders. I have had a sticky caliper that would cause the ABS to trigger. A short drive on a dirt road made it easy to figure out which wheel was sticking...
It could also be a bad ring tone sensor.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Old 03-30-2008, 03:04 AM   #14
speedbullet2
Ill x2 on this but everyone has their own opinion lets just all have some and call it a day
FUTURE MODS
Old 03-30-2008, 09:09 AM   #15
tsconver
Hooligan
tsconver's Avatar
2003 WJ
makes sense then, abs defintiely feels different than warped rotors as someone mentioned warped rotors can also be felt in the steering wheel as a wooble back and forth, abs usually does not cause a huge steering wheel pulse.
My Build Thread
A few goodies
2006 Red Liberty
Glock Forum
