About to order PSC steering box, ordering the right one? - Page 4 - JeepForum.com
post #46 of 51 Old 02-19-2013, 11:12 AM
PolkaPower
Originally Posted by bananaslug View Post
and if youve never done it, swapping it out is a *****, but it would be MUCH faster next time if I ever have to do it again.
I don't have a garage anymore. Just waiting for it to warm up a little. I need to get this cat converter on first. Inspection will be coming up soon and they nickle and dime you to death in this state for registration and DL.
PolkaPower is offline
post #47 of 51 Old 06-18-2013, 06:36 AM
PolkaPower
So I finally got the PSC box in. It wasn't hard to do at all just cumbersome with only one set of hands. When unbolting the old box I tied it to the frame so it wouldn't fall. When installing the new one I did the same so I could get the bolts started. Get a HD pitman arm puller. I tried the medium sized one and it was garbage. The HD one got the pitman arm off in less than a minute with no fuss. I used a large crescent wrench and a 4 foot pipe with the wrench stuffed into the end for leverage. I didn't even break a sweat. I also drained the PS fluid out of the pump for fresh fluid.
The slop and wandering are totally gone now but as Bananaslug said the steering wheel is a bit heavier. Takes a bit more effort to turn it but nothing bad. Overall a much better feeling when driving.
Bananaslug, I was wondering if you tired messing with the over the top adjustment to loosen the steering up a little? I backed the adjustment bolt off 1/4 turn and there was a slight improvement. I am having a hard time turning the adjustment bolt separate from the lock bolt though so I can't adjust it any more than that or the lock nut will be loose. There isn't enough room for me to get a good grip on the wrenches in there.
I am a little concerned that everything worked right away after the install. I turned turned the wheels back and forth half a dozen times and topped off the pump with fresh fluid and it was working fine after that with no more bubbles in the res. Nothing is usually that easy but I guess I am just paranoid.
Also the number on mine is SG 19387
post #48 of 51 Old 06-18-2013, 09:07 PM
Smokey1r
When i rebuilt my steering box there was a stiff or heavy feeling to the steering but after about 4k or so of use it went away and now is very easy to turn and the pre loads are still right where they should be. Its just all the new rings and seals breaking in.
Smokey1r is offline
post #49 of 51 Old 06-18-2013, 09:17 PM
PolkaPower
Cool. I backed off the top nut a little more and it feels really nice now. If it gets looser I'll tighten it back up. I didn't even stop to think that there would be a break in period. Thanks.
post #50 of 51 Old 06-24-2013, 08:27 AM
PolkaPower
After a bit of driving and a 40 mile trip I have to say that this is one of if not the best thing I have done to the Jeep so far. The steering feels great, like a new truck.
post #51 of 51 Old 06-27-2013, 09:56 PM Thread Starter
bananaslug
I didn't mess with mine at all. I didn't mind the steering wheel feeling when pushing the 33s, it felt sturdy. Im glad you like it so much Polka, its one of the expenditures you can feel whereas I usually feel like Im getting bled dry on silly repairs.
bananaslug is offline
