Abnormally fluctuating oil pressure? - JeepForum.com
post #1 of 4 Old 06-18-2013, 05:14 PM Thread Starter
Haleyrz
So I'm on my lunch break at work, and was going through a drive thru waiting in line, and I looked at my oil pressure gauge, and it was sitting a hair under 40 psi as it usually does as the engine is warming up. It usually sits at 32psi after its warm. Anyways, I noticed it drop to around 32, then go up and back down. Nothing erratic like if it were a malfunctioning BCM, more steady like if you were to press the gas. But I wasn't, I was idling the whole time. It did it a couple times. Should I be concerned? Maybe I've never witnessed the pressure drop while idling. Most the time I'm moving. Right now it's holding steady at 32 psi idling in the parking lot. Specs are 98 4.0, 215,500 miles. Running new Bosch filter and mobil 1 10w-30. Oil and filter have maybe 800 miles on them.
1998 ZJ Laredo, 4.0L, 2WD, it's boring
Haleyrz is offline
post #2 of 4 Old 06-18-2013, 05:44 PM
Oldfrog
2007 WK
Might be a bad oil pressure sensor....but I dont know.
Mine does that once in a while too. I dont get nervous until it drops below 25....which it never does.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 4 Old 06-18-2013, 08:10 PM
dnuccio
could be a bad pressure sender.
ive read that if you have 1 psi of oil pressure for every 100 rpm youre in good shape
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #4 of 4 Old 06-18-2013, 11:24 PM Thread Starter
Haleyrz
Meh, I won't worry about it then. There's no lights on, the jeeps runs great. Makes a little lifter noise, but what 4.0 doesn't haha
Haleyrz is offline
