A44HD Axle compatibility if any ! 1998 ZJ - JeepForum.com
post #1 of 7 Old 07-09-2011, 02:57 PM Thread Starter
divco13
Going to the you pull it bone yard, and see what they have for rear axle shafts.
What axles are interchange with the 1998 5.9 A44 if any !
What spline are the axles in a A44
May need replacement ones, when I take it it apart for inspection.
Starting to growl a little,.
Any body have any insite on what to look at ?
Mine is a 1998 ZJ 5.9
Bob
http://oldcarandtruckpictures.com/Divco/BobPatterson/
http://www.facebook.com/pages/Divco-Milk-Truck/102362503162366
divco13 is offline
post #2 of 7 Old 07-09-2011, 03:28 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
shafts from any ZJ with a 44A will work.
i think 44A's are 30 spline, but im not 100% on that, its just the number off the top of my head.
that growl your experienceing isnt caused my by a bad asxle shaft, its caused by bad bearings...the $$a is known for short bearing life due to housing flex.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 7 Old 07-09-2011, 03:34 PM Thread Starter
divco13
Most of the time when the bearing growls, it has taken out the shafts bearing surface.
Just need to be ready with a part source.
Bob
divco13 is offline
post #4 of 7 Old 07-09-2011, 03:38 PM
jforse
Only 44a shafts will work out of the junkyard. Otherwise Superior has 44a shafts available or you could use there Super35 shafts they are the same thing. They are 30 spline.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #5 of 7 Old 07-09-2011, 09:49 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
They aren't the same in the zj, different lengths.
You won't get the c-clip in
You can use 44a.shafts ina wj 35 since they're semifloat and 3/8" here or there won't matter much.
ratmonkey is offline
post #6 of 7 Old 07-10-2011, 09:37 AM
jforse
I used stock dana44a shafts in my super 35. They are exactly the same thing as the 30spline shafts superior uses.
jforse is offline
post #7 of 7 Old 07-10-2011, 12:25 PM
gothchick
Yukon also makes a nice forged chromoly 30 spline super 35 kit.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
Axle bearing dana a44hd 1998 zj divco13 ZJ Grand Cherokee Forum 1 06-06-2011 08:17 AM
Axle/Hub Compatibility rnrkid ZJ Grand Cherokee Forum 5 06-01-2009 10:28 AM
WJ Front Axle Shaft Compatibility? CanadianZed-J ZJ Grand Cherokee Forum 13 12-30-2008 08:59 AM
Quick compatibility question, axle housing UFO ZJ Grand Cherokee Forum 10 04-30-2007 11:11 AM
axle compatibility mythic ZJ Grand Cherokee Forum 9 02-23-2006 09:19 AM
