99 WJ rear right tire brakes/lockes up when turing (merged) - JeepForum.com
post #1 of 7 Old 07-21-2009, 10:48 PM Thread Starter
fizzer
Yesterday i switched my wj from 2wd to 4 full time and went off roading with it. After i got off the dirt i switched it back to 2wd and drove about two miles. when i noticed that it said i was in 4 part time on my dash when i never was. I switched it back to 4 full than 2wd and the part time light left. Now when i take deep turns my rear right wheel locks up and the tires screech and it feel as it is dragging. What happened?
fizzer is offline
post #2 of 7 Old 07-21-2009, 10:53 PM
gatorayde
The piece that holds the linkage on your T case probably fell off, take a look under your jeep and check the linkage going to the T case.
gatorayde is offline
post #3 of 7 Old 07-21-2009, 10:59 PM Thread Starter
fizzer
i did some research and some people said it might be my limited slip diff. or chipped spider gears. also im a noob so if you guys can help me out that would be great.
fizzer is offline
post #4 of 7 Old 07-21-2009, 11:01 PM
gatorayde
Again, check the linkage. It's common for the clip to break off and then the T case will be stuck in one gear setting.
post #5 of 7 Old 07-21-2009, 11:33 PM Thread Starter
fizzer
WJ rear wheels locks while turing.
My WJs rear right tire locks up and screeches as its being dragged when i take sharp turn. Some people said my t case linkage, spider gears are worn out or my limited slip diff. What can the problem be? im a noob so if you guys can help me out that would be great.
fizzer is offline
post #6 of 7 Old 07-21-2009, 11:59 PM
sandman
most likley limited slip locking up.. could need a rebuild but i would start with a fluid change with an extra dose of LSD additave.
1993 Jeep ZJ. 4.0
sandman is offline
post #7 of 7 Old 07-22-2009, 12:03 AM
01Limited45324
Why did you make two threads about it 30 mins apart?
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
Turing off MDS???? grebesjeep WK Grand Cherokee & XK Commander Forum 8 09-04-2009 11:11 AM
Rear brakes Q craddock01 ZJ Grand Cherokee Forum 0 05-11-2009 01:38 PM
hot rear brakes... dave01 ZJ Grand Cherokee Forum 8 03-17-2009 09:10 AM
Rear drums + mud = no rear brakes... aaron7 ZJ Grand Cherokee Forum 18 10-08-2008 09:55 AM
ZJ lifts...two threads merged Danno123 ZJ Grand Cherokee Forum 19 02-16-2008 04:04 AM
