-   -   99 WJ rear right tire brakes/lockes up when turing (merged) (http://www.jeepforum.com/forum/f13/99-wj-rear-right-tire-brakes-lockes-up-when-turing-merged-821897/)
fizzer 07-21-2009 10:48 PM
Yesterday i switched my wj from 2wd to 4 full time and went off roading with it. After i got off the dirt i switched it back to 2wd and drove about two miles. when i noticed that it said i was in 4 part time on my dash when i never was. I switched it back to 4 full than 2wd and the part time light left. Now when i take deep turns my rear right wheel locks up and the tires screech and it feel as it is dragging. What happened?
gatorayde 07-21-2009 10:53 PM
The piece that holds the linkage on your T case probably fell off, take a look under your jeep and check the linkage going to the T case.
fizzer 07-21-2009 10:59 PM
i did some research and some people said it might be my limited slip diff. or chipped spider gears. also im a noob so if you guys can help me out that would be great.
gatorayde 07-21-2009 11:01 PM
Again, check the linkage. It's common for the clip to break off and then the T case will be stuck in one gear setting.
fizzer 07-21-2009 11:33 PM
WJ rear wheels locks while turing.
My WJs rear right tire locks up and screeches as its being dragged when i take sharp turn. Some people said my t case linkage, spider gears are worn out or my limited slip diff. What can the problem be? im a noob so if you guys can help me out that would be great.
sandman 07-21-2009 11:59 PM
most likley limited slip locking up.. could need a rebuild but i would start with a fluid change with an extra dose of LSD additave.
01Limited45324 07-22-2009 12:03 AM
Why did you make two threads about it 30 mins apart?
The time now is 02:44 AM.
