-   -   99+ (WJ) intake swap belt question (http://www.jeepforum.com/forum/f13/99-wj-intake-swap-belt-question-1794209/)
zjosh93 11-15-2013 02:19 PM
93-95 ZJ with 99+ (WJ) intake swap belt question
I'm swapping a 99+ intake onto my 93 in about a week. My power steering pump is leaking and if I need to buy a rebuilt pump I'm just going to buy a 96-99 pump and turn in my 93 pump as the core. I already have the PS bracket and bolts for the 99 intake. I also might have a little crack in my twice-welded header so I'll probably re-re-weld that too. Welds seem to last about three years and I'm ok with that. I'm going to drill out all the fittings on the 99 intake and tap the holes 1/4" NPT so I can reuse all my 93 fittings. I have a spare set of 93-95 fittings. I'm going to put 1/4" NPT to 1/4" inverted flare fittings on the outer two side holes and bend up some 1/4" hard line to reach back where the MAP and CCV lines end so I don't need to extend any rubber vacuum lines. I already have 703 injectors.
After reading all the posts about the swap it seems pretty straight forward. My question is about the belt. It looks like most people remove the idler pulley under the AC compressor and run a 96-98 belt. Any reason not to just leave that pulley in place and run a longer belt. The stock 93 belt is 97.2 inches and longer belts are common. I'd like to keep that idler to maintain the extra belt wrap on the AC comp and alternator.
Thanks
riot1987 11-15-2013 03:48 PM
I kept all my existing pulleys and went with a different sized belt. No Issues. Cant remember the length though. I bought like 6 belts and returned all the ones that didnt fit lol
zjosh93 11-15-2013 04:13 PM
Alright, excellent. I was pretty sure it would work but I didn't see anyone doing it or a suggested belt length so I was worried that there was some weird Jeep gotcha that made it impossible to just buy a longer belt. Didn't want to get everything swapped out and discover a problem with the last step.
WhiteOut 11-15-2013 08:00 PM
The 93-95 PS pumps differ from the 96-98 pumps On the earlier ones, the pulley is set back about half an inch from where the 96-98 one sits. The difference is enough to shred the belt.
zjosh93 11-15-2013 09:01 PM
I was under the impression that by changing my 93 pump and bracket out for the 96-98 pump and bracket that the power steering pump pulley would line up with the rest of the belt drive. As I mentioned in my first post my power steering pump is leaking from the rear seal so I'm going to trade it in as the core for a 96-98 pump. I already have the 96-98 bracket to match it and I will just reuse my old power steering pump pulley on the new pump. It looks to me that the new power steering idler and bracket add about an inch or less to the belt so finding a longer belt shouldn't be an issue.
zjosh93 12-08-2013 07:36 PM
I installed my 99+ intake yesterday and I discovered why no one keeps the third idler in the swap. The idler nearest and to the right of the alternator adds a lot of belt wrap the the alternator in the 93-95 routing but the later model routing reverses the belt arrangement on the water pump and crank pulleys. On the 93-95 the belt routes to the left of the water pump and the right of the crank: on the later models it routes to the right of the water pump and the left of the crank. The up shot is the the belt going from the bottom of the crank to the alt in the 93-95 routing changes to come from the top of the water pump. This gives the alternator plenty of wrap. It looks like if you left the third idler the belt would interfere with the AC idler. On the later setup there is about 3/4 between the belt and the AC idler; without actually trying it looks like the third idler would move the belt up about that much. The additional pulley wouldn't add that much more wrap to the alternator at that point; maybe another 5-10 degrees. Certainly not worth the added complexity or extra failure point. I just bought a 97 4.0 belt and it all works perfectly.
zander21510 12-08-2013 08:04 PM
I don't think that's correct. I did the swap with my original 93 pump with 96-98 brackets and it lines up perfectly.
If you just use all 96+ parts, you shouldn't have a problem. You can find some good info on the swap in my signature :)
WhiteOut 12-08-2013 08:14 PM
The alignment issues I ran into were on a 5.2, so it might be different on the 4.0
zjosh93 12-08-2013 08:20 PM
Yep, I used all the 96+ stuff including buying a new pump to replace my bad original pump. With the 96+ belt it all worked fine even though I reused my old pump pulley and an older sized pulley for the adjuster. The 93-95 uses two 3" idler pulleys but the newer set up uses a 3.5" pulley on the adjuster. With the belt properly tensioned the adjuster was in the center of its range so it all worked out. I'm going to watch for any odd belt wear but the pump pulley alignment seems good. I may buy the correct adjuster pulley and pump pulley after the holidays.
My intake install is here: http://www.jeepforum.com/forum/f13/9...ution-1867410/
The time now is 03:50 PM.
