Jeep Enthusiast Forums banner
99 WJ has mind of its own......someone should know wut this electrical problem s/b
471 views 2 replies 2 participants last post by  superarmen
#1 ·
I have a 99 wj limited and have checked all the fuses, changed battery connectors & battery, but problem still occurs.
gauges dont work at all...none of the gauges respond ( i dont know how fast im going, at what rpm, how much gas i have, etc...)
While driving today I noticed that when i hit the turn signal, the gauges started working again and then dropped as soon as i turned off my turn signal....same thing happens when i turn the highbeams on.....it was very responsive becasue everytime i touched the turn signal or highbeam everything would work...
any idea as to what it may be?????
#2 ·
Take apart the steering column, and mess with the left stalk.
It might have a loose connection in there somewhere.
Go to wjjeeps.com, and look up automatic headlight installation procedure.
Basically it'll tell you what to do to take the left stalk out.
#3 ·
FINALLLLLLLLLLLLLLY!!!!!!!!!!!!!!!
It ended up being the HBL relay that was causing all the problems....had a new one as a spare so we used that and got the problem fixed....... it finnally helps to know how fast im driving and how much gas i have!!!! :2thumbsup: :2thumbsup:
Top
