#1 | |
'99 rotor question
Ive read all the problems with the brakes on '99s or so.
Saw something about 2 piece rotors? How can you tell if they are 2 piece or 1?
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#2 |
Search the forum for warped rotors and WJ. I'm pretty sure the 1 piece rotors are silver in color. Not sure about the 2-piece.
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust Nokian Vatiiva tires: 235/65-17 Previous:1997 ZJ TSi 4.0. Some stuff added Western New England College '08 Golden Bear Lacrosse #13 Week 11 USILA Rank: #15 2008: 16-5 NCAA Elite 8 TCCC Champions Please read and share!! |
#3 |
I know the calipers were different colors, you sure about the rotors?
#4 |
Sorry, I'm a ZJ guy. But check www.wjjeeps.com as well. Tons of info on that page. Us ZJ guys are jealous of that site
#5 |
This is an interesting manufacturing design concept. The composite rotor is junk. It is a lower base quality steel with a harder steel overlay. There will be a lip near the hub for this type. These are not to be confused with high performance composite rotors. They are for racing only. You want a full cast iron rotor (one solid piece). In general stay away from ceramic pads. These are clean and do not dust the rims as much but they also insulate the heat more. So heat dissipation is not as good and this heats the rotors which can cause warping. Semi-metallic pads will be dirtier but will not add as much heat to the rotors. If this is true then they should also stop at shorter distances! I warped a set of rotors within a week, after switching to ceramic pads.
On a different note: if anyone is going to have the rotors cut/resurfaced then it is to be done with them on the vehicle (with the rotors mounted to the hubs) to avoid hub run-out. This will give you the flattest surface possible. Many times it will be better than new rotors. This will cost much more however. You never cut a rotor if you previously have vibrations. Only cut rotors if there is no indication of warpage. People have rotors cut if the grooves are deeper than normal and you want two complete flat surfaces for maximum braking. If the grooves are too deep then the rotors needs replacement. That will be determined by the machinist.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#6 |
I was just curious if i could tell the 2 piece apart from the other. Its for a friend, I believe the '99 has around 70K on it.. so its somewhat possible these are the original rotors but I doubt it.
#7 |
$ 110 replaces both rotors and pads with DuraLast ones.
#8 |
4.0 Piston Skirt Victim
If you upgrade at all, get the upgraded Jeep calipers and brembo rotors. I also use stock pads and have had a signifigant increase in rotor life. It has not solved the issue, but the combination above has given me an extra 30,000 miles before they warp at all. This lifespan reasonably satisfies me and my wallet.
WALTER |
#9 |
Its not for me.. Personally I would not own a '99 limited.
Thanks..
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
