Quantcast 99 JGC Rear Drive Shaft Seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 99 JGC Rear Drive Shaft Seal
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 12-03-2006, 08:00 AM   #1
DRE97
2008 WK
Where the rear drive shaft attaches to the rear differential the seal seem to be leaking. Is this an easy fix?
Also, just took a closer look. Not sure if it leaking from the top of the Diff or the seal. Why would it be leaking from the top?
Dre97
DRE97 is offline   Reply With Quote
Old 12-04-2006, 09:38 PM   #2
DRE97
2008 WK
Dre97
Can't anyone help with this??
Old 12-05-2006, 03:08 PM   #3
mailforjon
mailforjon's Avatar
2005 WK
this is the rear pinion seal.
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline   Reply With Quote
Old 12-05-2006, 03:11 PM   #4
mailforjon
mailforjon's Avatar
2005 WK
Dre97
most likely leaking from the seal. never heard of one leaking from the top. unless there is absolutely NO gasket/RTV at the top for some reason and its sloshing around when youre driving and spitting out. 1,000,000:1 says its coming from the pinion seal.
-1993 XJ 2.5 [SOLD]
Old 12-05-2006, 03:24 PM   #5
///BHRpowered
Umm, somehow I don't think that sound easy. I have no idea how to disconnect my driveshaft, let alone drop it and remove this so called nut.
mines leaking from the TC pinion seal, but I got a quote of 150 to fix it
[url=http://www.mazdaworld.net/forums/index.php?showtopic=19]"Within the mind lies the greatest of all evils...Eternity" - Enigma02S[/url]
[url=http://www.cardomain.com/ride/2370949]2000 Millenia S...Five figure spending account[/url]
[url=http://www.cardomain.com/ride/2384051]1998 Jeep Grand Cherokee...Gone but never forgotton[/url]
[url=http://www.cardomain.com/ride/2383985]2003 BMW M3 SMG...For Sale, PM if interested[/url]
[url=http://www.cardomain.com/ride/2484240]2000 "Jeep Grand Cherokee...4.7, Quadra-Drive, Loaded.[/url]
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin - [url]http://www.mazdaworld.net[/url]
///BHRpowered is offline   Reply With Quote
Old 12-05-2006, 03:40 PM   #6
donkie
It could be coming from the vent tube...or the seal failed on the top side.
It depends on how you define easy, and you need some non standard tools.
INSTALLATION
(1) Apply a light coating of gear lubricant on the
lip of pinion seal. Install seal with an appropriate in
installer (Fig. 31).
(2) Install yoke on the pinion gear with Installer
C-3718 and Spanner Wrench 6958 (Fig. 32).
(3) Install a new nut on the pinion gear. Tighten
the nut only enough to remove the shaft end
play.
CAUTION: Do not exceed the minimum tightening
torque 298 N·m (220 ft. lbs.) when installing the pinion
yoke retaining nut at this point. Damage to
bearings may result.
(4) Rotate the pinion a minimum of ten times and
verify pinion rotates smoothly. Rotate the pinion
shaft using an inch pound torque wrench. Rotating
torque should be equal to the reading recorded during
removal, plus 0.56 N·m (5 in. lbs.) (Fig. 33).
(5) If rotating torque is low, use Wrench 6958 to
hold the pinion yoke (Fig. 34) and tighten the pinion
shaft nut in 6.8 N·m (5 ft. lbs.) increments until
rotating torque is achieved.
6) Install propeller shaft with reference marks
aligned.
(7) Fill differential with gear lubricant.
(8) Install the brake rotors and calipers.
(9) Install wheel and tire assemblies.
(10) Lower the vehicle.
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline   Reply With Quote
Old 12-05-2006, 03:44 PM   #7
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If it is leaking from the top of the differential cover, then it just needs a new seal...If it is leaking from where the drive shaft connects, then it needs a new pinion seal.
ArloGuthroJeep is offline   Reply With Quote
Old 12-05-2006, 03:46 PM   #8
mailforjon
mailforjon's Avatar
2005 WK
just replaced my TC seal last week. all said and done it took about 45 minutes. you can disconnect and remove the rear driveshaft by removing the 4 small bolts that hold two small c-clamps to the driveshaft. then it simply slides forward and pulls out of the transfer case, allowing you to pull the old seal and pop in a new one. on a scale of one to ten (with an oil change at a one for reference), id say its no more than a 2 and the only "special" tool you need is a seal puller.
-1993 XJ 2.5 [SOLD]
Old 12-05-2006, 06:44 PM   #9
DRE97
2008 WK
Rear Pinion Seal
Just took a few more to minutes check the leak at the rear differential.
The leak is at the rear pinion seal where the rear drive shaft attaches to the differential. The leak appears severe. The oil is all along the bottom of the differential and up the DF cover. Checking my Haynes manual, this appears to be a PIA job requiring special tools.
I usually try to do all my own repairs. Is this one outside the limits of a "shade tree mechanic"?
DRE97
Old 12-05-2006, 08:36 PM   #10
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
You can do it yourself if you want. It really is not that bad.
Search feature is friendly to those who use it!
http://www.jeepforum.com/forum/f13/diff-fluid-qs-332948/?highlight=Pinion+seal
-Tim GS-MW 2009 INFO
KD8EBC
'94 ZJ 5.2 LTD
Project TORTOISE Build-up thread
JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick
EMTimZJ is offline   Reply With Quote
Glock Forum
