The 99+ Intake Manifold HOW TO - Page 4 - JeepForum.com
post #46 of 85 Old 05-05-2013, 11:36 AM
AaronButler
I have a 96 GC, and from what I am reading... this should be pretty easy overall. I dont need to do the Power steering mod, and the only mods I might need to do are lengthen some of the hoses? am I right?
AaronButler is offline
post #47 of 85 Old 05-05-2013, 04:12 PM Thread Starter
zander21510
That is correct, overall pretty easy!
zander21510 is offline
post #48 of 85 Old 05-05-2013, 05:02 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Did torchd ever get the vacumn thing figured out?
Originally Posted by HighLonesome
coralman is offline
post #49 of 85 Old 05-09-2013, 11:55 PM
torchd
2003 WJ
I did. I ended up capping the nipple and making an ever so small little slit in the cap.
Idle went back to normal and no other problems
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #50 of 85 Old 05-10-2013, 11:41 AM
coralman
coralman's Avatar
Thanks for responding.
coralman is offline
post #51 of 85 Old 05-10-2013, 04:24 PM
PeteNnewburg
another intake swap.
I have just a few more items to collect for the swap! I got a '96 PS Pump and brackets this week, I still need the new belt. I also need to clean my 703 injectors, intake, TB and IAC. I am finishing up my rear end CA replacement, BB, Bilstiens, Prothane bushing & 3" exhaust. I had to take a few days off from the build, but will be back hard on it Monday.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #52 of 85 Old 12-14-2013, 03:02 AM
Football47
So the 96-98 zj is easier to work with...good. So the manifold can be taken from a 99wj or 99xj? I put in some upgraded injectors and the manifold would be a nice little addition for getting my max mpg outta the new ford 4-hole injectors I have...
Can't beat a Jeep
Football47 is offline
post #53 of 85 Old 12-14-2013, 03:06 AM
Football47
How long does this take to do? And anyone have the upgraded injectors, electric fan and 99 intake manifold? What would that get for gas mileage, or what does it get?
Can't beat a Jeep
post #54 of 85 Old 12-14-2013, 12:33 PM
OverlandZJ
The 96+ is easier as it already has the correct power steering pump/bracket.
Donor's are 99+ WJ/TJ/XJ..
Install time will depend on who's turning the wrench, i'v done numerous headers etc so I was familiar with the job. MPG is going to vary.. if you see an increase at all. The typical advantage of this swap is improved idle and throttle response, if your looking for a mileage increase you will most likely be disappointed.
I had the same issue as Torchd.. until I swapped the check valve around.
OverlandZJ is offline
post #55 of 85 Old 12-24-2013, 07:02 AM
RNMedic
subscribed
The only thing more powerful or reliable than a Warn is Chuck Norris getting out and pushing.. from Hussler on JF
RNMedic is offline
post #56 of 85 Old 03-12-2014, 10:12 AM
Ksrummel
Subbed...will be doing this to my XJ this weekend!
Ksrummel is offline
post #57 of 85 Old 09-24-2014, 09:51 PM
tetatdo
1994 ZJ
FYI - anyone in CA wants to do this, it is CA smog legal.
The tech wont notice the difference and it wont mess up your numbers. After I fixed my smog issues the truck blew a hair above the minimum on all numbers, HC, NO, CO, etc.
Question, are the 96-98 pumps different than 93-95? I did this swap many many moons ago, and now my power steering pump is leaking. I need to change it but I cant remember what pump I used..I do remember swapping it out.
tetatdo is offline
post #58 of 85 Old 09-25-2014, 07:38 AM
zjosh93
The 93-95 pumps are different than the 96-98. When I did the 99+ manifold swap I changed my pump out for a rebuilt pump. Told the parts guy to look one up for a 97. Hoses from the 93 fit the 97 pump just fine.
zjosh93 is offline
post #59 of 85 Old 09-25-2014, 11:00 AM
Marcos
The 93-95 pumps have threaded holes on on the pump body because they are bolted front and back to the brackets. The 96+ pump has straight drilled holes because the pump is sandwiched between the front bracket and the intake manifold, with long bolts that screw into threaded holes int he manifold.
I think someone re-used the 93-95 pump doing this swap by drilling open the holes on the pump to allow the use of the thru-bolts.
Marcos is offline
post #60 of 85 Old 09-25-2014, 11:51 AM
zjosh93
Someone did do that but the older pump is also a hair bigger than the later pump so he just kinda got the bolts going and let the threads jam against the older pump. I also think he was only able to get two of the bolts threaded. It worked, but I wouldn't want to have it that way if you ever have to take the pump out and back in more than once. Gotta get the later model bracket from the JY anyway so might as well grab the pump or take your chances with a rebuilt pump.
zjosh93 is offline
4.0 , 99+ , intake manifold , swap , xj
New 4.0 intake manifold 01xjltd ZJ Grand Cherokee Forum 3 10-05-2011 10:17 PM
Intake Manifold nashmd454 ZJ Grand Cherokee Forum 29 01-29-2008 08:40 PM
Intake Manifold martinr_zx440 ZJ Grand Cherokee Forum 0 08-06-2006 10:19 PM
intake manifold help tbone31 ZJ Grand Cherokee Forum 10 05-20-2005 10:09 AM
Intake Manifold nickcletus ZJ Grand Cherokee Forum 1 03-10-2004 04:55 PM
