The 99+ Intake Manifold HOW TO - Page 2 - JeepForum.com
post #16 of 85 Old 03-24-2012, 07:51 PM
LordHobbit
I meant no fuss. I just found it funny that someone who has helped so many had such a small post number. Thank you for your work and effort in instructing us. It'll help me I'm sure.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #17 of 85 Old 07-23-2012, 01:25 PM
torchd
2003 WJ
Zander, I'm bumping your thread bc I did my WJ intake install, all was good but I have a little problem.. I have no cruise control and my air blows on from the top of my vents. This is a sign of a vacuum leak.
Basically I was wondering, after your install did you have any problems? (loss of cruise control and air only blow from defrost)
I did fix it, but I technically now have a vacuum leak. In my thread (see link) It shows what I did to fix. Basically you know how we have 3 nipples on the side of the intake, you're not using one and neither am I so i capped it. Well that made me lose cruise control and my air settings. I pulled the cap off and now I have everyhting back to normal, but technically speaking I have a vacuum leak now.
How did you get yours to work w/o out any problems??
Can you post your vacuum lines and how you fixed them?
Here's my post http://www.jeepforum.com/forum/f13/i...ctors-1396015/
1998 Jeep Grand Cherokee Laredo
2" BB Pucks | SkyJacker Hydro Shocks | Rubicon Wheels | Cooper 245/75/16 Tires
2002 Trans Am
Cam, Full Exhaust, Stock Heads, Stock LS6 Intake and Stock 10 bolt with 3.42s
420 RWHP and 382 RWHTQ
torchd is offline
post #18 of 85 Old 07-23-2012, 11:48 PM Thread Starter
zander21510
Nope, after I installed the couplings for extending the lines and plugged everything in I had no problems at all....I read your post, how very odd...
I should put some better pics of the vacuum lines on here anyways I'll go take some pictures tomorrow to see if I can shed some light on the issue.
zander21510 is offline
post #19 of 85 Old 07-24-2012, 12:01 AM
torchd
2003 WJ
Thanks man.. Everything went well, jsut for some reason if I cap that nipple I lose my cruise and air settings. I leave that nipple unplugged I get my cruise back and my aire settings back, but then I have a vacuum leak.
Did you use any of your stock ports on the new intake, or use all the ports that came on the intake?
2002 Trans Am
torchd is offline
post #20 of 85 Old 07-24-2012, 05:21 AM
djjordache
responded in your other thread.
but also double check that you have the check valve installed the correct direction. pull it out and put it in your mouth and SUCK IT! you will have flow through it pulling air through it towards the engine (on the engine side of the hose.)
93' ZJ 4.7L Stroker, Claytons LONGARMS, 4wd conversion, 231SYE, HPD30, 8.8, 35's, etc....
djjordache is offline
post #21 of 85 Old 07-24-2012, 03:07 PM
torchd
2003 WJ
Yes my check valve is intalled the correct way
2002 Trans Am
torchd is offline
post #22 of 85 Old 07-26-2012, 01:00 AM Thread Starter
zander21510
Just letting u know not ignoring u I just haven't had a chance to get those pics....been busy but I will as soon as I can.
post #23 of 85 Old 07-26-2012, 01:48 PM
torchd
2003 WJ
Not a problem.. Once you post your pics, I'll prolly copy your set up and run my vac lines that way you ran them
2002 Trans Am
torchd is offline
post #24 of 85 Old 07-28-2012, 11:15 AM Thread Starter
zander21510
Think I might have found the problem. That vac line that goes to the cruise is shared with another line on the same little opening. The other line goes to the evap canister. Brake vac line goes straight in as does the CCV and MAP sensor.
post #25 of 85 Old 07-28-2012, 12:08 PM
jtackerman28
Heres the real question. Can you tell a HP difference?
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #26 of 85 Old 07-28-2012, 12:35 PM Thread Starter
zander21510
Well now I can't give you a number and honestly it doesn't drive much differently in normal flat conditions, but when u hit the pedal it picks up much better, and its very noticeably better maintaining speed up hills without downshifting. I don't think its downshifted up a hill since I put it on...and that by itself makes it worth it.
But I gotta say the exhaust and injector swap contribute as well...I doubt it would do much by itself
post #27 of 85 Old 07-28-2012, 01:18 PM
jtackerman28
I have 703 injectors and straight piped to a flowmaster.
post #28 of 85 Old 07-28-2012, 03:47 PM
torchd
2003 WJ
Yes, with the intake swap, header and injector swap the Jeep can easily accelerate. A lot less down shifting and can pick up speed quicker and more swiftly
2002 Trans Am
torchd is offline
post #29 of 85 Old 07-28-2012, 03:49 PM
torchd
2003 WJ
Zander
If you look in my pic, the vac line coming from the canister from the front drivers side is going into the intake. It is going into the middle nipples. It runs parallel with the air intake hose. Get what I'm saying To the right of the blue cap
2002 Trans Am
torchd is offline
post #30 of 85 Old 07-28-2012, 04:08 PM Thread Starter
zander21510
Mhm i see, but do you see how on mine it shares the nipple thing with the cruise line? Perhaps that has something to do with it, did you have on of those nipple things on your old manifold?
4.0 , 99+ , intake manifold , swap , xj
New 4.0 intake manifold 01xjltd ZJ Grand Cherokee Forum 3 10-05-2011 10:17 PM
Intake Manifold nashmd454 ZJ Grand Cherokee Forum 29 01-29-2008 08:40 PM
Intake Manifold martinr_zx440 ZJ Grand Cherokee Forum 0 08-06-2006 10:19 PM
intake manifold help tbone31 ZJ Grand Cherokee Forum 10 05-20-2005 10:09 AM
Intake Manifold nickcletus ZJ Grand Cherokee Forum 1 03-10-2004 04:55 PM
