99 Grand Cherokee Stalling Problem - JeepForum.com
post #1 of 17 Old 02-16-2008, 10:49 AM Thread Starter
pigoo
First let me apologize if this question gets asked a lot! I'm a member of other forums, and I know how irritating it can be to see the same posts over & over again!!!
But believe me, when the problem happens to you...it really sucks!
In any case, I tried to do all of the right things ahead of time:
- I searched the FAQ (it did not list any fixes for the stalling)
- I did a "JeepForum.com" search for "Grand Cherokee Stall", and got about 386 hits...but most of them didn't really apply (wrong vehicle, wrong year, different symptoms).
So here is my deal...I have a 1999 Jeep Grand Cherokee Limited (4WD)...with about 77,000 miles.
Symptoms:
- vehicle usually stalls within 15 minutes of driving (instant stall, no warning, no rough running)
- I get no warning lights on the dash after a stall
- if I let it sit for maybe 5-10 minutes, I can get it to restart, and then I make a "dash" for home, and hopefully I make it!!!
What I have done so far:
- I get no warning lights on the dash, but I ran an OBD-2 scanner check anyway, and get no codes.
- checked air filter...good
- checked for any loose or dirty electrical connections under the hood...found nothing
- checked electrical connection on coil pack...good
- checked throttle body...didn't look very dirty, so I didn't clean with spray.
- removed coil pack, and replaced spark plugs
That's it so far.
Next steps:
- thought about checking fuel pressure at the rail, but I don't have the gauge, and didn't want to spend $50 bucks unnecessarily.
- coil pack seems to be ok, so I don't think replacing it will help
- I have heard about cleaning the IAC & TPS...but nothing looked dirty in the throttle body.
But mainly...I wanted to check with all of the experts here on JeepForum.com first...before throwing a bunch of money at it for parts that may not be the problem.
So please, send your ideas my way!
Thanks,
- Nick
p.s. Sorry for the long post, wanted to provide as much detail as possible.
pigoo is offline
post #2 of 17 Old 02-17-2008, 08:22 AM Thread Starter
pigoo
I can't believe no one has any ideas!
pigoo is offline
post #3 of 17 Old 02-17-2008, 11:15 AM
dickensheets
Fuel pump???
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline
post #4 of 17 Old 02-18-2008, 09:54 AM Thread Starter
pigoo
Originally Posted by dickensheets View Post
Fuel pump???
Yes...I already listed that as a possible source for the stalling in my original post (which will require the purchase of a $50 fuel pressure gauge).
I was hoping to get more replies...to help narrow things down a bit, from the many possible sources for this problem.
Thanks for your reply,
- Nick
pigoo is offline
post #5 of 17 Old 02-18-2008, 12:32 PM
kmd1776
what engine do you have?? im assuming being a limited your running the 4.7L, which i really dont know anything about... but maybe spending 50 bucks on a fuel pressure gauge is a fairly cheap way to rule out any fuel problems....
04 wj limited; 4.7L V8, 247> 242hd swap; Hayden auxillary tranny cooler; BFG All Terrain 245/70/17; Moog Up-Country Coil Springs; Monroe Reflex Monotube Shocks; JKS BPE's; Chrome Overland tow hooks; Dynomax Ultraflow catback
kmd1776 is offline
post #6 of 17 Old 01-16-2012, 05:13 PM
AAA
If your Jeep is having stalling issues, it is up to you to make the NHTSA (National Highway Traffic Safety Administration) issue a recall for the year and VIN numbers for the vehicles with this problem. They issued a recall for certain 1996 Jeeps with this exact same stalling issue. Please either call them or visit the website and enter your info and stalling symptoms. Let's make Jeep fix what they need to.
Either call the NHTSA at 888-327-4236 from 8am-8pm M-F Eastern time, or go to www.NHTSA.gov and click on the right side where it says, "Report a vehicle or child seat defect".
You can also click on this link which takes you directly to the page to file a safety complaint. https://www-odi.nhtsa.dot.gov/ivoq/index.cfm
It does no good to complain unless we let them know about it. Enter a formal complaint about what your vehicle is doing and make them pay for the repairs.
AAA is offline
post #7 of 17 Old 01-16-2012, 05:16 PM
zjj
1994 ZJ
Idle air control motor? My 96 had same problems. That fixed it. What about a dead cell it two in your battery? Sounds far fetched but it also caused stalling in another jeep I had. Simple voltage test.
zjj is offline
post #8 of 17 Old 01-16-2012, 06:04 PM
badbird17x
badbird17x's Avatar
1994 ZJ
It sounds like something getting warm, them cooling off. Since you said coil ill presume 4.0 as 4.7 has 8 of them. Does your code reader have a live data feature? Will it die in 15 mins if it just sits idling? If so watch what it's doing as it dies.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #9 of 17 Old 01-16-2012, 10:35 PM
ExpeditionXJ
Pssst.. it's 2012 guys..
ExpeditionXJ is offline
post #10 of 17 Old 03-12-2013, 06:39 PM
rickaclaus
I'm having same issue '00 wj, i6. I replaced coil rail today, no luck. cranks over slowly. tomorrow will try crank sensor.
rickaclaus is offline
post #11 of 17 Old 05-26-2013, 08:35 PM
tensbar
Apparently I'm not alone.
Jeep started shaking intermittently, start up, stop lights, etc. Progressed to would not turn over 1st try , 2nd turn of key no problem. progressed to shaking, when gas depressed no power, very rough idle, sputtering etc. let it go in just idle for a few min and it would seem to catch and drive halfway decent , although still shake at lights, and not a lot of power. Shop said bad Fuel pump. Changed fuel pump, no change, was told bad O2 sensor, new sensor no change. check engine light is on but no codes retrieved. When this first began, Spark plugs looked like crap, replaced them all and it worked perfectly. for one day. sometimes when driving there is a loud "popping" noise coming from what sounds like the glove compartment area, like air popping. Also replaced the coil as well. Today I was hoping that maybe something I replaced was responsible for the plugs to go bad so fast so I replaced those, still a little hesitation when starting, but no stalling or shaking. Im guessing if that doesnt work for long, ill try crankshaft sensor than as a last resort PCM.
tensbar is offline
post #12 of 17 Old 05-26-2013, 08:50 PM
Oldfrog
2007 WK
http://www.jeepforum.com/forum/f13/i...l-fix-1487443/
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #13 of 17 Old 05-26-2013, 09:07 PM
iser
so why is a thread from 2008 being necro-ed in zj forum?
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #14 of 17 Old 09-23-2013, 10:14 PM
calholli
jeep problem
I know this post is old, but people still read it.. so I'll just add my experience.... 99 4.0 auto 4x4....
I was having the same type of problems.. getting codes for Cam sensor and coil pack.. engine would randomly stutter and die... sometimes trouble starting, stuttering hard and simply not running..
I read alot, seen how everyone was changing many things with no results.. I wanted to avoid this, but I too got sucked into spending some money before I figured it out for CERTAIN..
new coil pack, new cam sensor, new "crank sensor", took the computer apart to attempt to re-sodder the board(read it somewhere, wrong year)...
each time it seemed to fix it for a couple of days, then act up again... and just before I decided to burn it to the ground........
FIX:
I crawled under the jeep and tapped on the newly installed "CRANK SHAFT POSITION SENSOR" with a long extension and it fired right up!!
turns out the crank sensor (which is nearly impossible to get to) is very sensitive as to how DEEP it is installed... if it is pushed in TOO CLOSE to the flywheel, it will cause it not to function correctly.. so you have to pull it out maybe 1/8 in as you tighten the mounting bolt.. I have not had any problems since, not even a misfire..... there is no code for CSPS, it usually will trip the cam shaft sensor code instead... so all of you out there pulling your hair out, focus on the CRANK SHAFT POSITION SENSOR'S INSTALLATION... 90% chance it will fix your problems
calholli is offline
post #15 of 17 Old 09-23-2013, 10:16 PM
calholli
FIX:
calholli is offline
2000 Grand Cherokee Stalling problem garyo WJ Grand Cherokee Forum 6 04-17-2016 02:40 PM
95 Grand Cherokee Stalling Problem hondajeep ZJ Grand Cherokee Forum 10 04-16-2012 12:13 PM
99 Grand Cherokee stalling Cirus ZJ Grand Cherokee Forum 4 04-16-2012 12:09 PM
96 grand cherokee stalling dirt machine ZJ Grand Cherokee Forum 2 09-15-2007 07:30 PM
Stalling Grand Cherokee Hammerhead ZJ Grand Cherokee Forum 2 12-06-2001 10:50 PM
