99 grand cherokee laredo needs help. - JeepForum.com
post #1 of 8 Old 07-12-2009, 03:31 PM Thread Starter
usafvet98
I could really use some help on this one. I have a 99 grand cherokee laredo 4x4. It is our only vehicle at the moment, and as a disabled vet, am running out of funds to fix the thing. My girlfriend tried to go out with my 2 year old son today and when she put the truck in reverse the drivers side wheel is jumping. It only happens in reverse and when I look out the door when going in reverse, it appears that just that wheel gets stuck as it goes round. I hear a pop every full resolution. I pulled the wheel, checked the rotor and pads, checked everything on the surface and all looks good. What could this be?
I was thinking rear wheel bearings? If it is, are they hard to replace on my own? I really cant afford to pay my mechanic to do it.
Please advise
Thanks
Brian
usafvet98 is offline
post #2 of 8 Old 07-12-2009, 09:22 PM
sullivanpunk
I have never done it but I would say its a piece of cake. This link http://www.jeepforum.com/forum/f310/how-replace-axle-shaft-wheel-hub-bearing-assembly-w-pics-377208/
Is a rough step by step some one else posted. I see you said you are a disabled vet but depending on your disability you may need help from a buddy. But if you can take the tire off you should be good to go.
The best resource I have found for this kind of stuff is a Haynes manual, you can pick one up at auto part stores and they WILL have perfect step by step instructions for it and some times even let you know tips/tricks.
THANKS FOR YOU SERVICE!!
2000 Grand Cherokee Laredo, V8 4.7, Quadratrac 2 TC, 255/70/16 Uniroyal Liberator AT tires with stock height, Flowmaster Super 40 muffler
sullivanpunk is offline
post #3 of 8 Old 07-12-2009, 09:24 PM
xJoshxx
2012 WK
OP said Rear wheel bearing Whole different beast than the front.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #4 of 8 Old 07-12-2009, 09:26 PM
MEinSoCal
here is a better DIY guide...
http://www.jeepslimited.com/index.ph...d=22&Itemid=98
MEinSoCal is offline
post #5 of 8 Old 07-12-2009, 09:32 PM Thread Starter
usafvet98
Thanks for the reply. Do you know from what I described if it is the bearing?
Originally Posted by sullivanpunk View Post
I have never done it but I would say its a piece of cake. This link http://www.jeepforum.com/forum/showthread.php?t=377208
post #6 of 8 Old 07-12-2009, 09:33 PM
xJoshxx
2012 WK
Lol now that i read it closer Sounds like you need a NEW cv Joint Did you check thoose if the boots are tore up the grease is gone and they dried up and broke,
2011 WK2 ORA2 sold
xJoshxx is offline
post #7 of 8 Old 07-12-2009, 09:38 PM Thread Starter
usafvet98
They are pretty dry but not torn up from what I could see. I noticed a clunking yesterday, and this morning she tried to go in reverse and it pops on every revolution. Forward seems to be fine.
post #8 of 8 Old 07-14-2009, 02:21 AM
RedlegWJ
Sounds like CV's definitely. If you were closer, I'd help out. You should be able to pick up a pair for under $200. Maybe there is somebody on here closer that could offer a hand? How many miles? Might be a good idea to knock out the bearing cartiridge while you're there too, if you had the funds.
RedlegWJ is offline
95 grand cherokee laredo Gmurph89 ZJ Grand Cherokee Forum 4 10-10-2008 10:01 PM
Grand Cherokee 3.1 TDI Laredo erasmuslj ZJ Grand Cherokee Forum 6 08-19-2008 02:39 PM
98 Grand Cherokee Laredo norsegod2007 ZJ Grand Cherokee Forum 4 10-21-2007 02:19 PM
97 Grand Cherokee Laredo rschuler ZJ Grand Cherokee Forum 4 07-12-2004 01:51 PM
Add-ons for a 93 Grand Cherokee Laredo Rdsxbaseball ZJ Grand Cherokee Forum 4 03-23-2003 11:40 AM
