99 GC tail light electrical mystery solved... I think - JeepForum.com
post #1 of 3 Old 07-29-2009, 05:05 PM Thread Starter
mrjeep
My wife's 99 GC has always had issues with the right side tail light. In particular the turn signal bulb would stop functioning. The bulb was not blown nor was the fuse. I would simply need to jiggle the bulb socket a little and it would work fine for a few months and then stop working again.
The other day I noticed the rear parking light on the right side was out. I pulled the housing and found that the plastic supporting the light bulb socket had melted. As a result one of the metal tabs that makes contact with the bulb socket was loose. I used an epoxy putty to rebuild the housing around the bulb socket. However, I thought about what could have caused the plastic to heat up to the point of melting. After a beer or two I thought about arcing. I noticed that there were indentions on the metal tabs of the housing where the socket rests... almost like wear spots. So I decided to use electrical solder over these indentions thinking that this would ensure good contact between the housing and bulb socket. It appears that the bulbs are now working as normal. I hypothesize that the tabs on the bulb sockets wore into the metal tabs on the housing enough to cause arcing. This generated the heat that caused the plastic to melt. This is also the reason that my turn signal bulb kept failing. Hopefully this is a permanent cure. I've attached some pics in the hopes that this may help others. If I'm wrong I blame it on the beer I'm drinking right now. Please notice the yellow circle around the wear spots I mentioned.
Jim
mrjeep is offline
post #2 of 3 Old 07-29-2009, 10:08 PM
WahooCreek
I had the same problem with mine on a 2000 WJ (found JF when searching for solution) and ended up ordering a new brake light from somewhere in California. You can search and find where people use sandpaper and other methods for cleaning the contacts, but none of that ever worked for me. What would work for a week or two was simply to pulled the socket with light bulb from either the backup light plug or the turn signal. However, eventually it would do the same thing.
Hope your fix works for you.
WahooCreek is offline
post #3 of 3 Old 07-29-2009, 10:48 PM
xJoshxx
2012 WK
lol same thing happened to me i just bought a new tail light $40 bucks new from ebay and 3 Brand new tail light sockets $7/piece from morris4x4
problem solved
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 01:29 AM
head light discoloration solved!!! froadin orvis ZJ Grand Cherokee Forum 12 06-23-2009 12:58 AM
Left Tail Light is Very Dim- Electrical Problem? pCarson92 ZJ Grand Cherokee Forum 10 11-20-2008 02:06 AM
Tail Light Mystery F. Paul ZJ Grand Cherokee Forum 11 05-07-2006 08:02 PM
Check Engine Light Mystery sunflash2012 ZJ Grand Cherokee Forum 5 03-15-2006 03:33 PM
