99 GC Limited dual climate problem - JeepForum.com
post #1 of 2 Old 10-17-2004, 01:27 PM Thread Starter
DavesMatthew
DavesMatthew's Avatar
When i turne my heater on high on both sides, the driver side blasts hot air and the passenger side blows freezing air. Whats the deal?
'95 4 cylinder
6" Rough Country Suspension
33x12.5 BFG AT's
Tuffy overhead console
Hella lights
SmittyBilt Backpack Rack
DavesMatthew is offline
post #2 of 2 Old 10-17-2004, 01:35 PM
Meerkat
It's a ratio thing. In other words, you can have 80 degrees out of one side, or 60 degrees on one side with 20 degrees on the other side, or 40 degrees on both sides.
You can believe that, or you can look at the other two or three active heater control problem threads we have going right now.
Essentially, one of your blend doors isn't working. The plastic gear may be stripped, the door may be jammed, or the motor may be bad. Do a search on blend door to find the other recent posts to learn how to pull the codes and repair your problem.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
how many people have not had a problem with dual climate TravisL1213 ZJ Grand Cherokee Forum 0 03-08-2007 01:13 AM
01 Limited Dual Climate Problems twowheelfreek ZJ Grand Cherokee Forum 2 10-31-2006 11:10 AM
Dual zone climate control problem, please help! CorvetteZ06 ZJ Grand Cherokee Forum 3 06-19-2006 09:50 AM
'01 WJ Dual Climate Control (yes, that problem) SoloTSi97 ZJ Grand Cherokee Forum 9 12-22-2004 06:45 AM
Problem With Dual Climate Control Overland2002 ZJ Grand Cherokee Forum 2 11-21-2004 11:44 AM
