99 G Cherokee 4.0 won't shift out of first! - JeepForum.com
post #1 of 9 Old 11-14-2006, 04:20 PM Thread Starter
Shawn w
I have a 99 Grand cherokee 4.0 4WD. It will not shift out of first at all. It goes in reverse and drive fine. Goes in all 4wd settings fine.It acts just like if you pull the shifter all the way down in to the 1 st gear selection. It does not try to change at all just keeps reving till you let off the gas and then revs down. The fluid is clean and full, and there are no warning lights of any kind on. It seems wierd that the tranny would just go out like this, they usually slip. This one seems like soemthing electrical is going on. Any help is appreciated.
Thanks,
Shawn
Shawn w is offline
post #2 of 9 Old 11-15-2006, 01:50 PM Thread Starter
Shawn w
can anyone offer any help?
Thanks,
Shawn
Shawn w is offline
post #3 of 9 Old 11-15-2006, 01:57 PM
Wiley
Wiley's Avatar
Is it throwing any codes?
Justin
1993 ZJ Laredo
5.2 V8 4" lift 31s JKS f & r track bars JKS discos Cragar Soft 8s DT 3000s OME Stabilizer
K&N drop-in Dynomax Exhaust Hella 500s Westin Safari Bar KOR Radiator Support
Dark Rosewood Jeep Club Member #5
Wiley is offline
post #4 of 9 Old 11-15-2006, 02:01 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If drive & reverse works and 1st gear does not, then it seems like a cable adjustment?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 9 Old 11-16-2006, 04:11 PM Thread Starter
Shawn w
i checked codes and it only came back with done so I guess it is clear. Still looking for some answers.
Thanks,
Shawn
Shawn w is offline
post #6 of 9 Old 11-16-2006, 07:47 PM
pulsepb
sounds like a transmission speed sensor. mine gave me a code and started doing exactly what you saying its an easy fix. just like changing a spark plug
pulsepb is offline
post #7 of 9 Old 11-16-2006, 08:54 PM
corningjeff
My 99 GC did the same thing over a year ago. Turns out the inner transmission seals were worn & needed to be replaced - an expensive fix. Does it start to shift normally after the engine/tranny warm up? Mine did this, as the heat allowed the seals to swell a bit. However, over time it eventually didn't shift well even when warm.
corningjeff is offline
post #8 of 9 Old 11-16-2006, 09:40 PM
GrandchampWJ02
2006 WK
Same thing happened to me in my 4.0 XJ a couple years ago. I had a check engine light though. It turned out to be the throttle position sensor (TPS). I believe it was about a $40-50 plastic sensor that was really easy to replace. Just a suggestion and I'm not sure if this will help with a WJ.
--Reid
'06 WK Laredo 4.7 Light Khaki
Colorado Jeep Club Member #36
Previous Jeeps:
'02 Black WJ Laredo 4.7, '96 Cherokee Classic Moss Green
GrandchampWJ02 is offline
post #9 of 9 Old 11-17-2006, 07:34 AM Thread Starter
Shawn w
well i pulled the codes and there weren't any, and no it does not try to shift at all. just stays in first with out even attempting to shift.
Thanks,
Shawn
Shawn w is offline
95 grand cherokee won't shift to OD cratebv212 ZJ Grand Cherokee Forum 3 11-22-2009 04:50 AM
Shift Problem 95 Grand Cherokee gromey ZJ Grand Cherokee Forum 0 04-24-2009 08:36 PM
93 grand cherokee hard shift ttavenieriii ZJ Grand Cherokee Forum 0 11-20-2008 05:30 PM
Shift kit for 97 jeep grand cherokee bvilletigers08 ZJ Grand Cherokee Forum 2 07-08-2008 03:51 PM
93' GR Cherokee 3rd-to-OD shift problem LEXMan ZJ Grand Cherokee Forum 17 05-31-2005 06:21 AM
