99 4.0 wj oil leak help - JeepForum.com
post #1 of 6 Old 06-23-2009, 07:53 PM Thread Starter
spoiler8
hey new to the site, theres alot of great advice out there but im still having some trouble with my problem. I have a 99 grand Cherokee with the 4.0 and recently it started leaking oil. It has about 167,000 on it so after doing some reading i thought maybe its the rear main, but the drivers side of the oil pan is really rusted out and it is also covered with oil. The oil is all down the side of the pan, but it is also down the back and on the front of the transmission. Today i cleaned it up a bit and tried to patch it but the rust goes pretty far up. My question is if i cant stop the leak how hard will it be to remove the pan to replace it. Just from looking at it it seems impossible to get out without removing some major parts. Most of the posts about removing the oil pan ive found were on the Cherokee's so im not sure what all ill have to remove it.
Thanks alot guys
mike
spoiler8 is offline
post #2 of 6 Old 06-23-2009, 08:28 PM
00RedWJ
2006 WK
Thanks alot guys
mike
Don't think its that bad a job. It's been discussed here before. They do rust out sometimes.
2000 Red Laredo WJ
4.0 with Selec-trac - Sold
2006 Black Laredo WK
3.7 with 95,000 Miles
00RedWJ is offline
post #3 of 6 Old 06-23-2009, 08:56 PM
JG_Canuck
You'll have to dicso the exhaust pipe at the manifold, remove the starter and likely an engine mount.
Canadian Jeep Club Member Forty-Two
JG_Canuck is offline
post #4 of 6 Old 06-23-2009, 11:40 PM Thread Starter
spoiler8
Thanks alot for the info, at first i thought it was the rear main cuz it only leaks when its warm, but since the oil pan is coated on the side i doubt the oil would be running forward with the vehicle moving. Its just weird it doesnt leake when its cold maybe because the oil isnt as thin....beats me.
spoiler8 is offline
post #5 of 6 Old 06-25-2009, 09:35 AM
Greentrails
Its a pretty easy to do. I was a little apprehensive before dropping my pan, but once you get started and pull it off its not that hard. You also might want think about changing the valve cover gasket aswell. Found a little leak from the rear of the cover. My WJ has around 160,000 miles and it was definitely time to change those gaskets. Now, no oil leaks anywhere. As far was removing exhaust pipe at the manifold, starter and engine mount, I didn't have to do any of that. Although, I noticed how much easier it would have been to remove those, but its do able without have to remove those items. Just need a little patients.
Good luck.
Greentrails is offline
post #6 of 6 Old 06-27-2009, 12:13 AM Thread Starter
spoiler8
Thanks guys the jb weld worked for now but i plan on changing it in a few months since places i cant get to are pretty bad. I also noticed alot of crud on the rear of the valve cover so might as well add that to my list.
Thanks alot for all your help.
spoiler8 is offline
Anybody ever used Bar's Leak or Alumaseal radiator stop leak? scarthearmada6 ZJ Grand Cherokee Forum 23 05-02-2014 03:10 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 04:58 PM
2003 JGC I6 codes 442 medium leak and 455 large leak samsdad ZJ Grand Cherokee Forum 0 08-28-2007 11:17 AM
fron driveshaft join leak and pinion seal leak. GRDCHRKE555 ZJ Grand Cherokee Forum 1 12-12-2006 08:10 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 09:42 AM
