98 zj with some problems - JeepForum.com
post #1 of 2 Old 07-20-2009, 05:49 AM Thread Starter
jims98zj
I know some of these problems might have been posted a lot but I didn’t find the answer. I have a 1998 ZJ with a 4.0-liter engine
First problem is my cruise control stopped working. It started when I was driving down the road and it was just as if I hit the brake and turned it off. I would then reset it and it would be fine. Then it got to be when I would go to set it again it would not set at all. Finally the latest is the cruise light will come on with switch then turns off right away. This is very confusing to me since when the problem started the light would always come on. The next problem started about the same time as the cruse control issue. My transmission seems to slip but only between 55 to 65 MPH. It slips for less than a second and at regular speed it works just fine. It doesn’t do it all the time but it is often. These problems started a couple years ago but I would like to fix them as soon as possible so any help would be much appreciated.
jims98zj is offline
post #2 of 2 Old 07-20-2009, 10:28 AM
elmer_fud
for the cruise control check the vacum lines and make sure you don't have a leak
I am also wondering if maybe one of your speed sensors is acting up and that is causing the problems
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
99 WJ AC Problems ClockStoppa ZJ Grand Cherokee Forum 6 03-02-2009 04:04 PM
99 WJ AC Problems ClockStoppa ZJ Grand Cherokee Forum 1 03-02-2009 11:41 AM
Mudding problems.....What do you guys do to prevent problems? JackAysJake ZJ Grand Cherokee Forum 8 02-23-2009 09:02 PM
zj problems texas_jeep_guy ZJ Grand Cherokee Forum 29 03-20-2008 12:51 AM
Alternator problems??? Shock problems??? rflem550 ZJ Grand Cherokee Forum 11 01-24-2007 06:41 AM
