98 ZJ scan INCOMPLETE? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 98 ZJ scan INCOMPLETE?
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 02-12-2015, 08:27 AM   #1
PoorOtis
Repaired a Fault Code(P0301 cylinder #1 Mis-fire) with new tune up and new injector(off ebay for $13.) now shows No Code..drove 55 miles..then to inspection station,they pluged in code reader..shows No Codes..but..says Evap System & 02 Sensor Heater INCOMPLETE!!?? How long do I have to drive it for the computer to reset its self..or is there another way around this to get the old jeep inspected?? All Ideas will be helpful! Thanks.
PoorOtis is offline   Reply With Quote Quick reply to this message
Unread 02-12-2015, 08:57 AM   #2
MrRoundel
It may be that you need to go through 40 warmup cycles to complete the monitoring, and reset the computer. This, according to the FSM. A mechanic with a high-end bi-directional scanner could probably get around this, but I don't know if there's another shade-tree-mechanic-friendly way. Some mid-level scanners do have indicator lights that show, via red, yellow, and green LED's, whether you are ready to pass an emissions inspection. This is based on the monitored systems either failing (Red), being incomplete (yellow), and all monitoring completed and passed (Green). Perhaps the ones that you can borrow from Autozone have this capability? I know this because I just bought a used one over at "da Bay", that has this feature. Good luck.
MrRoundel is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 06:29 AM   #3
coralman
I can wish can't I?
coralman's Avatar
I'd check the wiring to the 02's just for drill.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 02-13-2015, 06:34 AM   #4
ZeeJay1997
Drive cycles
See attachment
ZeeJay1997 is online now   Reply With Quote Quick reply to this message
Unread 02-13-2015, 09:00 AM   #5
MrRoundel
Originally Posted by ZeeJay1997 View Post
See attachment
Much better than 40 warm-up cycles. That's a handy post. Thanks.
Unread 02-13-2015, 10:52 AM   #6
ZeeJay1997
if find it very out of the ordinary to drive some of the cycles. kind of hard to do in traffic. i dont know if they still do it, but the factories used to have tracks set up outside to drive through all of this.
