98 ZJ rear hatch stuck closed - JeepForum.com
post #1 of 18 Old 02-01-2012, 12:21 PM Thread Starter
MrKevinRosales
My aunt's ZJ's rear hatch handle is broken. It is still there but it won't open the hatch. tried locking/unlocking with the key and still doesn't open.
Any ideas on how i can get it open?
MrKevinRosales is offline
post #2 of 18 Old 02-01-2012, 12:26 PM
E-rok
does the handle feellike its locked or does it feel "stuck"
with mine, I have to hit unlock on the door a few times in a row and it frees up the hatch, then I have to push on the hatch while I pull the handle, if that makes any sense to you.
mine probably needs to be greased, its a common issue on ZJ's
2011 WK2 Laredo X Hemi
2008 XK Overland Hemi
2015 F150 3.5 Ecoboost
E-rok is offline
post #3 of 18 Old 02-01-2012, 12:32 PM
zander21510
I have read that there is a hole behind the licence plate that allows you to open the latch...if you need to get it open
zander21510 is offline
post #4 of 18 Old 02-01-2012, 12:34 PM
E-rok
I sure as hell hope thats not true lol
I thought you had to pull the interior panel to access it.
E-rok is offline
post #5 of 18 Old 02-01-2012, 12:42 PM
zander21510
Lol I think there was a thread about someone got their jeep busted into or something along those lines...someone chimed in the hole behind the licence plate there is a bar you can lift or push or something to release the latch on the liftgate. I might try to see if its really true today
I guess I should just screw my licence plate in with some really weird foreign screw so you can't take it off without a special tool
post #6 of 18 Old 02-01-2012, 12:44 PM
gabrod72
X2 until I fixed it. Had to adjust the latch, pin and adjust the door bumpstops. It works fine but rattles a bit now so next time I'll also adjust the door hinges.
gabrod72 is offline
post #7 of 18 Old 02-01-2012, 01:20 PM
JesterKirby
Mine has this same problem and I get it open the same way.
JesterKirby is offline
post #8 of 18 Old 02-01-2012, 02:10 PM Thread Starter
MrKevinRosales
Yeah there is one there, but you have to have access to the inside of the hatch to be able to open it because there are 4 nuts that need to be removed from the inside.
so i've managed the get that hole open and part of the inside cover so i can pull on it to see inside, but i'm not yet seeing anything usefull
post #9 of 18 Old 02-01-2012, 02:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The rod to the latch is held in place by a plastic clip.that slips and you can't open the hatch without pulling the panel and adjusting that clip., theres about 9000 threads on it here and at least 30 write ups.
ratmonkey is offline
post #10 of 18 Old 02-01-2012, 06:06 PM Thread Starter
MrKevinRosales
So i got it open. Turns out that the rod had slipped off
and i am missing that white piece.
went down to the dealer to see if i could get it, but i guess I'd have to buy the whole latch assembly
Any ideas on how to fix it?
post #11 of 18 Old 02-01-2012, 06:10 PM
zander21510
Head over to the junkyard, get the part you need. Bet they won't even charge you if its a little clip
post #12 of 18 Old 02-01-2012, 07:36 PM
KoreaZJ
1994 ZJ
and i am missing that white piece...
Which year? My '94 has a metal clip, not plastic.
KoreaZJ is offline
post #13 of 18 Old 02-02-2012, 01:05 AM
NWZJ
1994 ZJ
mine has same problem as well, also it rattles alot. is that due to the same reason it gets stuck?
NWZJ is offline
post #14 of 18 Old 02-02-2012, 01:12 AM
KoreaZJ
1994 ZJ
Remove latch mechanism, remove dust/dirt, lube well with silicone spray grease while actuating, put it back together.... before it gets stuck, breaks the clip, and it won't come open.
KoreaZJ is offline
post #15 of 18 Old 02-02-2012, 08:47 AM Thread Starter
MrKevinRosales
it's a 98, right now it just has a little groove where the rod goes, but when you pull on the handle the groove moves up the rod freely
rear hatch , zj
Hatch Stuck Closed webibeay ZJ Grand Cherokee Forum 10 05-29-2011 03:52 PM
rear hatch is stuck That Guy ZJ Grand Cherokee Forum 7 01-23-2007 02:36 PM
Hatch stuck closed 1996 GC b_critical ZJ Grand Cherokee Forum 10 05-09-2005 06:23 AM
Help! Rear Hatch stuck closed mjc1301957 ZJ Grand Cherokee Forum 2 12-21-2003 01:27 PM
Stuck Rear Hatch smiley ZJ Grand Cherokee Forum 7 05-13-2003 08:16 PM
