98 zj no start, no crank, no codes - JeepForum.com
post #1 of 8 Old 06-19-2013, 03:35 AM Thread Starter
ThundROkieZJ98
vert recently replaced thermostat, it wasn't opening and coolant sprayed a lot in engine bay via failed rad cap. next evening driving along for 30 minutes and engine shuts down. I try to start while still rolling in neutral but won't catch.. it would crank and it seems there's a lot of fuel in the fuel rail but it wouldn't start. towed it to shop . now it won't give codes to my mechanic. he thinks the antifreeze from failed thermostat my have damaged the pc PCM he said there was some on the PCM does anyone have any ideas?
ThundROkieZJ98 is offline
post #2 of 8 Old 06-19-2013, 03:37 AM Thread Starter
ThundROkieZJ98
my
post #3 of 8 Old 06-19-2013, 07:50 AM
dellis
2005 WK
I think you need a different mechanic that knows a little more about Jeeps ... the PCM, despite all its problems, is well-sealed against liquids.
So, the thermostat didn't open and the radiator cap spewed a bunch of antifreeze (I'm assuming into the container by the PCM)? Sounds to me like your Jeep overheated in a significant way, and (if so) you may be looking at something much more expensive than a PCM. If it overheated, you might want to have your mechanic check for mechanical problems related to an engine overheating, such as a warped head, cracked head, blown head gasket, etc.
dellis is offline
post #4 of 8 Old 06-19-2013, 09:44 AM
JohnnyZJ
so you have a 'no spark' issue that has no codes? coil.
if theres no codes theres other crap wrong with your jeep too though.
post back when you get it back and fixed
07' JKUR rollin on 35s
JohnnyZJ is offline
post #5 of 8 Old 06-19-2013, 12:01 PM Thread Starter
ThundROkieZJ98
thanks guys gonna do some investigating
post #6 of 8 Old 06-19-2013, 12:23 PM Thread Starter
ThundROkieZJ98
ok so I misunderstood my mechanics explanation apparently.i thought he was saying no codes. evidently he was saying the code he did get was saying I had a bad PCM .
post #7 of 8 Old 06-19-2013, 01:06 PM
dellis
2005 WK
What is the code? He should be able to tell you the code.
dellis is offline
post #8 of 8 Old 06-19-2013, 07:52 PM
ZeeJay1997
Water can migrate into the connectors, but not the PCM.
Disconnect battery, remove water reservoir, disconnect PCM plugs and blow them out with air or let them air dry.
Once that is done and reassembled, turn switch on an see if the CEL comes on for 3 seconds. If it does the PCM is alive, but not necessarily healthy.
If it got hot enough to blow coolant out the reservoir, the head probably warped.
ZeeJay1997 is offline
