98 ZJ - need to know everything about a 3.5 inch lift! - JeepForum.com
post #1 of 30 Old 03-20-2013, 09:13 AM Thread Starter
Vortexium
Rough Country Jeep ZJ Grand Cherokee 3.5" Suspension Lift Kit 1993-1998
Kit Contains:
Front: Lifted coil springs, lower control arms, sway bar links, and crossmember spacers.
Rear: Lower control arms and track bar bracket (factory front coils are used to lift the rear).
Shocks: (4) Premium N2.0 series nitro shocks
100% bolt-on installation
Features application valved N2.0 series shocks which offer the best in balanced performance for on and off-road use.
Note:
Does NOT fit models equipped with CV style shaft on the front differential.
V-8 models includes front 0.75" coil spacers.
Stock front coil springs are moved to lift the rear.
Estimated Install Time: 2-3 hours
Max Tire Size: 31 x 10.50
Wheel Backspacing: stock
-------- that's all from fatbobs garage.
Okay, so all I hear is you need a TC drop, SYE, track bar brackets are ****. Well I need to know EVERYTHING I'm gonna need for this lift. One, I KNOW I need a u-joint conversion.(links please,prices.) would you please help me figure all of this out. I have a mechanic on hold to put on that lift for 200 bucks + the parts. Need a total price for it all. Thanks!
Vortexium is offline
post #2 of 30 Old 03-20-2013, 09:38 AM
mig1289
That lift rides just like it's name, rough. Is recommend something differen
2wd zj...
mig1289 is offline
post #3 of 30 Old 03-20-2013, 09:45 AM
jeepinbassist
Also check out the IRO 3.5" lift. That one comes with a front adj. track bar and the bracket just no control arms. I've been looking at both of them and I'm still deciding which one would be better.
jeepinbassist is offline
post #4 of 30 Old 03-20-2013, 09:54 AM
MTBlue
Huge X2 on the IRO lift. I ran it on my 94 and it was absolutely fantastic. If you upgrade to 4 new coils (instead of the f->r swap) its about $100 more but definitely worth it, especially if your springs are sagging at all. I also upgraded to the Nitro shocks (from Rough Country), also VERY worth it. Good on and off-road manners. The kit is very comprehensive, and as a first kit, it was a fairly easy installation, even with how I rednecked it
Definitely a huge fan of IRO, and with all the upgrades I sprang for (4x new coils, nitro shocks, shock boots), the kit came out to around $600-650 with shipping and handling included in the price. 110% worth it, IMO.
Hope it helped!
-Evan
Dirt Deprived
MTBlue is offline
post #5 of 30 Old 03-20-2013, 10:01 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sir,
do yourself a favor, delete Fat Bob's garage from any history file you may have and you'll be much happier.
IRO, KOR, RE will be much better for you.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 30 Old 03-20-2013, 10:08 AM Thread Starter
Vortexium
Thanks for the help guys. But is a tc drop it SYE necessary even for a 3 inch spring lift?
post #7 of 30 Old 03-20-2013, 10:13 AM
ramthis426
2005 WK
Don't mind them man the rough country lift is a great lift I've ran them in three dif jeep a xj wj and a zj they ride fine a lot of people hate on them because of the bushings in the arms but they can be replaced with other brands.
05 3.7 wk QT1,2.25 Old Man EMU,255/75/17 GY silent armors,call of duty black moabs,Spidertrax
1.5,Pinch weld & rear fender mod,hypertech max energy.1992 jeep xj larado 4.0,4.5 rought country lift, coustome built rear bumper with tire swing soon to be on 33s
ramthis426 is offline
post #8 of 30 Old 03-20-2013, 10:23 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sir,
no SYE kit is needed even at 6.5 of lift. Feel free to buy what you want but, if you have to buy it and then change the bushings and then Christmas is on the 26th vice 25th and they make you change your birthday to have the kit work, it may not be worth it. Check IRO, KOR, Kolak (from my sig) or Rubicon Express. That's 30 years of 4x4 driving trying to help you.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 30 Old 03-20-2013, 11:21 AM
MTBlue
If run for a long time, Rough Country springs start to sag if run for a long time. I've heard some bad things about RE too but I've never actually run into anyone who has run that kit, so I really don't know. Fill in the blanks on the bad side of both if you would, Hunter
Dirt Deprived
MTBlue is offline
post #10 of 30 Old 03-20-2013, 11:59 AM
ramthis426
2005 WK
Only the add a leaf kit sag the full leaf will hold up
Sent from my jeep while driving trying not to wreck reading these stupid Questions you ask
post #11 of 30 Old 03-20-2013, 12:22 PM
Rich93ZJ
There are no leafs on a ZJ. OP, do yourself a favor and take our advice. Go with the IRO not the RC.
Rich93ZJ is offline
post #12 of 30 Old 03-20-2013, 12:37 PM
ramthis426
2005 WK
Yea I know I said that wrong I've spent all day replacing leaf bushings. What's your real problem with rc it's cheap and will last him for a couple years before he gets any sag by then he can upgrade to something else
post #13 of 30 Old 03-20-2013, 12:47 PM
dougmorgan99
I run the IRO 3.5 lift with their Double Sheer Front Adj Trackbar, Rear Adj Trackbar and new rear coils. Their parts are pure beef! I went cheap and did the Rough Country Hydros. Like everyone says... ran like a dump truck on road but nice control offroad (less body sway). Since I am on road 95% the time, I changed to Bilsteins 5100 I ordered from Kolak. Rides a world of difference on road and still okay offroad. So decide if you are building a daily driver or trail rig and go from there as far as shocks.
Note: No TC drop needed. I had a CV joint front Drive shaft and did fine for moderate offroad. Went ahead and changed it when I did my NP242 TC swap. Just had to get a DS shop to shorten it a bit. The rear DS doner was fine for my lift. I am going to do all full adj IRO short arms in the spring...
dougmorgan99 is offline
post #14 of 30 Old 03-21-2013, 06:48 AM Thread Starter
Vortexium
Appreciate it fellas!
post #15 of 30 Old 03-21-2013, 07:55 AM
Roskoe
IRO cant beat their customer service
"aut viam inveniam aut faciam"
I hate when old people poke me at weddings, point and whisper, "You're next." So I've started doing the same thing to them at funerals
Roskoe is offline
