98 Zj laredo ABS light came on once.. - JeepForum.com
post #1 of 16 Old 03-23-2013, 05:28 PM Thread Starter
ZjRW
Noticed the ABS light on while driving home. When I pulled into my driveway I Pulled up my handbrake then let it down again, the ABS light went away. I started up the jeep twice more and the ABS light didn't come on. You guys think it's my ABS or just a faulty sensor?
Forgot to add: my jeep is 1998 ZJ 4.0 i6. Brakes changed a year ago, battery changed half a year ago.
ZjRW is offline
post #2 of 16 Old 03-23-2013, 06:00 PM
RTLee
Maybe a fault on one sensor. If you have a scan tool, try monitoring your speed sensors for one dropping out. Otherwise, I'd let it go until it comes on and stays.
I am not sure if it would be stored in history codes if it went back off. Worth a try to scan.
RTLee is offline
post #3 of 16 Old 03-24-2013, 07:29 AM
grego
1994 ZJ
It may be a sensor fault if you are lucky. Mine came on when I had a brake line leak near a tire. I assume it just got enough fluid aroudn there to make it hard for the sensor to function.
I never actually took a look at that sensor after the brake line was fixed and the light has stayed on indicating ABS. Since I really am not a fan of ABS brakes on my jeep, so I like that they aren't functioning right now and I have regular brakes.
grego is offline
post #4 of 16 Old 03-24-2013, 07:56 AM
BlastMasta
Easy fix
Remove All ABS relays and fuse
Unplug ABS pump
Remove all speed sensors
Remove ABS light from cluster
FIXED
BlastMasta is offline
post #5 of 16 Old 03-24-2013, 09:10 AM
Pierre_r
1989 XJ Cherokee
Untill you crash and the insurance wont cover anything because YOU disabled a safteysystem.
Pierre_r is offline
post #6 of 16 Old 03-24-2013, 09:12 AM
riot1987
Originally Posted by BlastMasta View Post
Easy fix
Unplug ABS pump
FIXED
Ive done 2/4 of these things
Build thread^^
riot1987 is offline
post #7 of 16 Old 03-24-2013, 09:14 AM
misfit77
What insurance? you guys have insurance on your old Jeep?
misfit77 is offline
post #8 of 16 Old 03-24-2013, 09:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
No scanners other than the Chrysler drbiii and snap on solus can read abs data. The wheel sensors do not report anything to the pcm.
Abs is a convenience, not a required system. Still millions of vehicles on the road without it and they stop just fine.
ratmonkey is offline
post #9 of 16 Old 03-24-2013, 10:44 AM
BlastMasta
What kind of crappy insurance would take the time to look for that?. Lol. Just dont wreck it
In the state of PA it is not mandatory to have ABS
Also the braking system works better without ABS. You just need to know how to drive
I prefer not having ABS and performing my own brake pumping. You have more control over the vehicle
post #10 of 16 Old 03-24-2013, 12:27 PM
Exdecuk
In the dry or snow / ice yeah but not in the wet on the street IMHO
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline
post #11 of 16 Old 03-24-2013, 02:18 PM
BlastMasta
Snow, ice, rain?
I understand these are all different braking situations; but in every one of these situations i would prefer manual, boost assist, braking
ABS is over rated
My humble opinion
:P
Some people would prefer ABS and would rather keep it operational
Not this guy
post #12 of 16 Old 03-24-2013, 10:55 PM
dean477
OP, I have the same year and trim jeep. My light came on and off a few times awhile ago. I took it to a buddies shop with the scanning tools and it was a speed sensor. he said not to worry, but if i wanted to, i could take the fuze and relays out to have a non abs braking vehicle. As the members above have stated, its a preference. But as an Emt who has seen too many accidents...I'd keep the modern safety feature that the jeep was designed to have on it. especially if you didn't grow up in the 70's/80's and have experience with non abs cars. You don't want to make your first emergency maneuver without abs and not know how to properly use the big pedal or not know how the truck is going to react...
Dean
dean477 is offline
post #13 of 16 Old 03-25-2013, 02:06 AM Thread Starter
ZjRW
Thanks for the replies guys. I do have insurance on the jeep and do not intend to disable the system just yet I have been keeping a close eye on the truck and the light hasnt come on since.
ZjRW is offline
post #14 of 16 Old 03-25-2013, 02:37 AM
KillNThrill24
ABS? The hell is that? Some new invention? Lol every vehicle I've owned has had broken ABS and traction control.
Check all your sensors (if you wish) or just leave it alone. As long as you know how to drive you really don't need it, and the ABS light won't do anything but annoy you. I get scared when mine goes off..
KillNThrill24 is offline
post #15 of 16 Old 08-19-2013, 06:08 PM
bluefever
has anyone tried the actron CP9580A? it says all obd2 vehicles.
bluefever is offline
