98 ZJ factory alarm glitch..How to I disconnect it? - JeepForum.com
post #1 of 8 Old 08-07-2008, 10:16 PM Thread Starter
MyZJ98
Hey guys, I have a 98 jeep grand cherokee laredo with the factory chrysler alarm system built into it, and it had the little remote with the 'unlock', 'lock' and 'panic' buttons on it, and when you press the lock button, it engages the alarm system. Lately though, when I lock it with the keyless remote, the alarm will later randomly go off. There's no specific time it goes off, nothing that causes it, no loud noise or any disturbance, but it just goes off, and sets the horn off, and it won't disengage until I press the lock button or it goes on for the full 3 minutes. I'm really not making good friends with the neighbors when my alarm is going off for no reason at 3am, plus it's just beginning to get on my nerves and I fear if it keeps going off so often, it will kill my brand new battery! So my question is, how can I disable the alarm so when I press the 'lock' button, it simply just locks the doors? I've already disbabled and removed the 'panic' button from the remote, thinking maybe something in my pocket would hit the button and cause it to go off, but that still didn't fix it. I even tried to just unplug my horn, but even that, I could get my hands on top of the horns to unplug them, so that plan failed too... please help me out, I'm running out of ideas and getting frustrated and really don't wanna have to take it to the stealership to have them tinker with it if it was something I coulda done...
Thanks,
Derek
Derek
'99 WJ Laredo 4.0L, 174K, NP242 (Current)
MyZJ98 is offline
post #2 of 8 Old 08-07-2008, 10:31 PM
WhiteOut
WhiteOut's Avatar
Im having the same issue, no clue as how to fix it. I havent locked the Jeep in almost 3 weeks because of it, I just use my Club.
WhiteOut is offline
post #3 of 8 Old 08-07-2008, 10:53 PM
moparrr07
the zj theft module is part of the bcm, so it could be that malfunctioning or one of the door switches going bad, or the hatch, or the headlight switch
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #4 of 8 Old 08-07-2008, 11:37 PM
tirus89
tirus89 is offline
post #5 of 8 Old 08-08-2008, 10:28 AM
CLNinja
CLNinja's Avatar
#1
#2
Originally Posted by tirus89 View Post
#1 will most likely fix your problem, but theres a possibility it wont and it costs money to replace the switches
#2 will permanently disable your alarm so it never works again... so if you want to have an alarm you will have to put on an aftermarket alarm. As you can see ( since i wrote that link ) i have disabled mine and i put on a DEI Viper alarm with remote start. If after reading that you still need more help disabling your alarm, pm me and i will help you all i can
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #6 of 8 Old 08-08-2008, 10:34 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
remember it is an alarm system that is designed to be difficult to circumvent. generally stuff that disables the alarm disables the jeep too.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #7 of 8 Old 08-08-2008, 10:40 AM
CLNinja
CLNinja's Avatar
grounding out the alarm like in that link WILL NOT effect the rest of the Jeep at all... i have had it done for a year and many others have done it for quite some time.
Now if you go pulling fuses or try to pull out the Alarm Module your Jeep will not like you at all
Matt
CLNinja is offline
post #8 of 8 Old 01-02-2009, 09:59 AM
JGC1998
2007 WK
If you ground out your 98, you will end up with the lights on in the interior all the time, tried it. Check the other forums about security systems on 'em. If you do figure out a good solution, let me know, I have the same issue on my 98 ZJ. I just lock the door with the key for now.
JGC1998 is offline
2000 grand fact, alarm disconnect?? mopar2256 ZJ Grand Cherokee Forum 0 07-03-2009 11:29 PM
factory alarm arms but wont sound off the alarm sdowney717 ZJ Grand Cherokee Forum 4 04-18-2009 07:09 PM
Disconnect the Panic alarm feature jnkarrik ZJ Grand Cherokee Forum 2 08-11-2006 07:17 AM
Disconnect the alarm! ddoffroad ZJ Grand Cherokee Forum 1 09-10-2005 10:51 AM
How can I disconnect my factory alarm? Jimmygcl ZJ Grand Cherokee Forum 4 08-03-2002 06:28 AM
