98 ZJ Do I need a new Fuel Pump - JeepForum.com
post #1 of 2 Old 09-20-2009, 10:10 AM Thread Starter
purple_jeep
Hi Guys,
I think I need a new fuel pump but I thought I would check here first. The problem is when its been sitting for a while it takes alot longer then normal to start. I bought a Fuel pressure meter and these are the readings I got:
Normal pressure when Its been running is about 42psi
Cold pressure first thing in the morning 22psi
Cold pressure if I turn the key on then off without starting then on again is 42psi
When I did the key on and off then on again I was able to start straight away.
I also just replaced the PCM for another issue.
Thoughts?
Cheers
Chris
purple_jeep is offline
post #2 of 2 Old 09-24-2009, 07:01 PM
ytudrepus
1994 ZJ
There's a bypass valve on the fuel rail.
I could be sticking, there is a procedure to check in the Hanes manual.
ytudrepus is offline
New aftermarket high quality fuel pump? second pump in 3 years?!!!!? SPL Tech ZJ Grand Cherokee Forum 8 11-02-2010 05:12 PM
Fuel Pump & Fuel Lines - Connections jeremiahgreer ZJ Grand Cherokee Forum 5 02-02-2010 04:19 PM
No fuel pressure, Fuel Pump? CPS? ECU? Relay? 95cherokee33s ZJ Grand Cherokee Forum 2 10-22-2008 08:57 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 18 04-09-2008 07:28 PM
Fuel Pump/Fuel Tank Problem ma-usa1 ZJ Grand Cherokee Forum 0 02-05-2003 06:02 PM
